STD Tuning Engine OM606 throttle
OM606 throttle
OM606 throttle
whipplem104
04-10-2015, 12:56 PM #1
Ok,
So I am working on a 722.6 swap for a customer that has a N/A 606 and will be swapping later to a Turbo. I am looking at the throttle linkage for a TPS setup and realized that this will change with the turbo engine. What setup are you guys using for the mechanical pump in the turbo engines? I want to make sure that I locate everthing so it is easy to change the TPS later. Pictures would be great.
This is in a w124 chassis.
whipplem104
Ok,
Petar
7.5mm M pump
459
04-10-2015, 01:48 PM #2
You could retain the NA throttle linkage in the turbo motor if you make a cutout in the intake manifold.
Petar
whipplem104
04-10-2015, 01:54 PM #3
Do you just then weld in a boss for the mounting bracket?
whipplem104
Petar
7.5mm M pump
459
04-10-2015, 04:32 PM #4
Here's how @HoleshotHolset did his
Manifold cutout
[Image: attachment.php?aid=5841]
Welded custom bracket:
[Image: attachment.php?aid=5846]
Finished linkage:
[Image: attachment.php?aid=5847]
[Image: attachment.php?aid=5848]
[Image: attachment.php?aid=5849]
Some other people attach the cable directly to the pump and use the place where the fuel heater was mounted for a bracket.
[Image: IMG_1361.jpg]
I personally don't like this solution but hey it works  Smile
This post was last modified: 04-10-2015, 04:36 PM by Petar.
Petar
Manifold cutout
Finished linkage:
whipplem104
04-10-2015, 07:11 PM #5
Sweet. Thanks.
I like the way I am doing the TPS on the original transmission cable location with this setup. It looks factory. So when the T-engine goes in I will just do that setup. Keep it simple.
whipplem104
Sweet. Thanks.
whipplem104
04-10-2015, 08:04 PM #6
Here is what I came up with.
whipplem104
whipplem104
04-10-2015, 08:09 PM #7
This is the tcu placement and harness layout in the car.
whipplem104
