STD Tuning Engine IP for OM604
IP for OM604
IP for OM604
greenmachine
04-02-2015, 01:34 PM #1
Hello , i am replacing a crappy lucas pump on a OM 604 910 with a bosch M pump from a vito 110D .
also i intend to mount a turbo using a outlet from a OM 605, my aim is about 180- 200 hp max .
can someone tel me if i need to replace elements on the pump or for this value of Horsepower , its elements will do ??
also, does anyone know the model of the pump ? i still have to search for one :-)
has any of you done this ? can you give me some assistance ?
thanks a lot Wink Wink
greenmachine
Booster
04-02-2015, 03:33 PM #2
If it's a mechanical pump then yes I think new elements are needed, if its electronic then 200 hp is fine.
The 6mm elements from the electronic pump can go in the mechanical pump for no ecu 200hp
Booster
Petar
7.5mm M pump
459
04-02-2015, 04:16 PM #3
200hp might be possible with a 6mm pump, but just barely, remember it's only a 4 cylinder. ~180hp should be easy.
Petar
F.R.A.S
04-03-2015, 02:54 AM #4
The Vito 2.3dt IP has 6mm elements but it's not of the same type as the electronic 6mm so they can actually not deliver more then max 55cc of fuel I'm afraid. You need to either change that to real 6mm elements or go 7.5mm or 8mm.
Otherwise the 2.3dt IP is great. High RS# and easy to mount a throttle linkage on and so on.
F.R.A.S
04-03-2015, 07:23 AM #5
hello,
Regarding the pump, i can find u one, PM me.
for the turbo i belive i have one laying around, so u just miss the exaust colector, something that wont be diff.
boa sorte.
hello,
boa sorte.
greenmachine
04-16-2015, 12:46 PM #6
ok, and for me to reach 200whp or 180whp, do i need to get diferent injectors ? which ones, or from what engine ?
if using the original injectors, what do i need to change to reach that power ?
greenmachine
04-16-2015, 12:55 PM #7
u need to pm me.
i´ll help u out with that build.
regards
u need to pm me.
regards
