Turbocharger help
Turbocharger help
Hi there to all some help please .
I am currently doing a project installing a om606 into a boat I have sent my injector pump to dieselmeken so while it is away I want to work on setting up my stock turbocharger Goran over at dieselmeken recommended 7.5 mm element and I am planning to use my stock turbo . So the question is this what is the best waste gate actuator to install on a stock turbo any help would be greatly appreciated
Darrel
In my upion if you have in mind to even bothyer with the original turbo you should tke mout a sledge hammer and let it speakso you no longer think aboutr theold one, they do not take muck before they go balistic... but this is my personal feeling about the oroginal turbo so please do not take it personal, what are your power goals?
go to a junkyard and start digging. try to get something off a cummins truck, a saab 9-5 (preferrably aero) or a 3.0t audi.
(04-18-2015, 12:51 AM)ak47is1337 go to a junkyard and start digging. try to get something off a cummins truck, a saab 9-5 (preferrably aero) or a 3.0t audi.
(04-27-2015, 05:07 PM)Daz Bye the way I'm from Ireland . I can source loads of truck turbos the holset turbo from a daf 45 is readily available holset h1c . What do you think of them ??
The big H1C uses the same comp housing and comp wheel as a HX35 so perhaps 300is? You'll need and external gate as well.
Probably same turbine but different size compressor wheels. The HX35 has at least 4 different compressor wheels but all have the same turbine.
(04-29-2015, 10:20 AM)ak47is1337 what are the differences between the "big" and "small" H1C?
