STD Tuning Engine Should I put HX40 and 7.5mm for everyday use?
deviance
HE351VE
88
07-09-2015, 09:48 AM #1
Hey guys!
My engine is now om606 7mm and KKK K27 It spool about 3500-4000 with only 1.3 bar (no smoke after that).
Should i put HX40 and 7.5mm for everyday use or that's too big for it? 4000+ spool?
Thank You!
deviance
Hey guys!
Thank You!
TurboTim
07-09-2015, 10:33 AM #2
Powerband will be 4500 and up. The power will be good but it is a compromise of losing low end. I have a 300SDL and pull a trailer a lot and I am having to rev the hell out of it to get any usable power going up hills or I am just rolling coal.
76 300TD custom lots of stuff
TurboTim
deviance
HE351VE
88
07-10-2015, 06:21 AM #3
maybe hard to overtake cars? Smile
deviance
erx
w202 om606
323
07-10-2015, 11:17 AM #4
I have om606 with 7,5mm diselmeken pump and hx40 with 16 housing. For everyday use it's not perfect but it's driveable. I have 1 bar boost at 3000rpm and 3bar at 4000rpm, it comes alive from 3500rpm. For everyday use I recommend smaller turbo because you really have to let rpm up to make it pull.
erx
Booster
07-10-2015, 01:01 PM #5
(07-10-2015, 06:21 AM)deviance maybe hard to overtake cars? Smile
Not If your in the right Gear  Dodgy
Booster
deviance
HE351VE
88
07-13-2015, 06:57 AM #6
Thanks for the answers!
@erx: What manifold do you have?
deviance
