STD Tuning Engine 606 turbo activator
606 turbo activator
606 turbo activator
gary andrews
4x4 builder
48
08-30-2015, 02:59 PM #1
are the standard 606 turbo activator good the use when you put on a super m pump. if not what to use cheers
c250 std at mo
gary andrews
c250 std at mo
starynovy
08-31-2015, 09:34 AM #2
You mean wastegate? No, its controlled partialy by vaccum also you can not set pressure without ECU. Why use stock turbo with superpump?
starynovy
gary andrews
4x4 builder
48
08-31-2015, 01:42 PM #3
so which one do i need. only starting on standard and working my way up with turbos.
c250 std at mo
gary andrews
c250 std at mo
