STD Tuning Engine High EGTs kill
High EGTs kill
High EGTs kill
Torkey
Dirty Diesel
220
09-14-2015, 09:00 PM #1
Had a race this weekend and in the process blew a boost hose.  The driver noticed on the front straight that the EGT gauge was pegged at 1600 degrees.  Took out the turbo.  Here are some pictures for those that like looking at failure porn.  My space os limited here but there are more pictures on our Facebook page if you want to see all the gory details.
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
09-14-2015, 10:08 PM #2
On the bright side, you didn't melt a piston Big Grin
In tractor pulling and many other diesel sports as well (I guess anything boosted) we weld tabs to each pipe and bolt them so they can't escape one another. Most times the boots don't blow, but rather the tubes seperate from the force and cause the boot to blow off.
Just my past experience Smile
This post was last modified: 09-14-2015, 10:26 PM by MFSuper90.
Torkey
Dirty Diesel
220
09-14-2015, 10:26 PM #3
Fortunately, it was a cheap Ebay turbo.  Could have been so much worse if we had a proper name brand turbo. :-)  I would hurt to only get 9 hours out of that.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
m1tch
09-15-2015, 01:54 AM #4
Which Ebay turbo was it btw? Just curious due to the other thread about them.
m1tch
Torkey
Dirty Diesel
220
09-15-2015, 07:51 AM #5
It was an F-Diesel brand.  I really don't think it was the turbos fault though.  Something like this would kill any turbo.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
09-15-2015, 12:40 PM #6
Do you use a worked pump yet?
Torkey
Dirty Diesel
220
09-15-2015, 12:46 PM #7
I'm using a stock MW pump that I have turned up. We weren't running that much boost, only 25 lbs. The coupler blew because it had another clamp rubbing against it.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
Torkey
Dirty Diesel
220
09-15-2015, 07:44 PM #8
Pulled out the turbo cartridge and found an artifact from the meltdown.  A small ball of metal the used to be the turbine wheel.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
atypicalguy
09-16-2015, 01:01 PM #9
The solution to high egts is usually more booist afaik. Where were they running before the blowout?
atypicalguy
