STD Tuning Engine om605 turbo oil feed
RickyE
10-10-2014, 05:53 PM #1
Hello
I was wondering what yous are doing for the oil feed pipe when fitting bigger turbos?
Do i need to use the stock end at the block and weld a fitting onto it for a longer pipe?
Cheers
RickyE
Hello
Cheers
Duncansport
10-10-2014, 06:23 PM #2
I just used 3/8th (10mm)steel line and reused the factory fitting and made my own bubble flare pipe to the turbo.
Duncansport
RickyE
10-11-2014, 05:50 AM #3
I was considering going to an fittings, but the only 16x1.5 adaptors i can find are flat faced and i dont know if they would seal on the block
RickyE
Max
Turbinaaa
87
10-11-2014, 08:53 AM #4
Hi,
i also jused An-Fittings for my OM602.
[Image: cbm5b27u.jpg]
[Image: 6vii8ki6.jpg]
Works perfect, no leaking
Max
Hi,
RickyE
10-12-2014, 06:40 AM #5
Thanks max, ill order the an fittings
What size pipe did you go for?
RickyE
Max
Turbinaaa
87
10-12-2014, 02:52 PM #6
Hi,
I used Dash 6 ( 9/16 - 18 UNF ).
Max
Hi,
Repetitio
09-23-2015, 11:11 AM #7
hi got a question...i got myself some flex lines and dash fittings. But for oil feed to the turbo i dont have the fittings. The tube has got 14mm diameter in the inside. Wich dash fittings should i take? dash 4? dash 6? for the 21mm return line i got dash 10...
Repetitio
09-24-2015, 11:29 AM #8
We used a compression fitting on the hardline coming out the block, (cut it with 3" sticking out). it converted to 3/8" BSP hydraulic fitting but you can get them to AN.
Like that
http://www.hoses.co.uk/hydraulics/hydrau...light-duty
This post was last modified: 09-24-2015, 11:29 AM by Hario'.
Like that
Repetitio
09-24-2015, 01:14 PM #9
ah ok, thanks but got myself some fittings from the m16x1,5 to the 3/8 npt from the hose already. Hope it fits and no leaks then  Dodgy
This post was last modified: 09-24-2015, 01:15 PM by Repetitio.
Repetitio
minim
09-24-2015, 03:20 PM #10
I made mine like this today. Used the old stock hardlines and bended them so it fit. This is a mix of 603 and 606 hoses joined togheter Smile Will make a support for the hose onto the top later. I was thinking about AN connectors and steel braided hoses but the guy I spoke with at the hose specialist told me to keep the hardlines when it's close to high temperature equipment like manifold/turbo.
[Image: IMG_1227.JPG]
minim
Petar
7.5mm M pump
459
09-25-2015, 04:36 PM #11
IMHO hard lines are better if you have equipment to make them, good choice. They can't flop around like hoses do and they look much more professional. Hoses on parts that don't move look like an unfinished job.
Petar
09-26-2015, 05:02 AM #12
Ermeto couplings make this easy Wink Two spanners is all you need Big Grin
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
10-02-2015, 09:31 AM #13
Looks very good!
Looks very good!
atypicalguy
11-24-2017, 11:35 AM #14
(10-10-2014, 06:23 PM)Duncansport I just used 3/8th (10mm)steel line and reused the factory fitting and made my own bubble flare pipe to the turbo.
What sort of tubing wall thickness, tubing bender and flare tool do you use? I am rigging up compounds, so I will probably put a T near the block and run hard lines from there.
atypicalguy
 11 Guest(s)
 11 Guest(s)
