STD Other Projects 1985 300td euro 5spd swap turbo diesel
  • 1 Vote(s) - 2 Average
Pages (2): Previous 1 2
10-01-2015, 10:54 PM #51
She lives again after 3 years of silence. I still need to pull the turbo and fix a leaky intake manifold gasket so i can get some boost and bleed the clutch and brakes and install the exhaust system
10-03-2015, 06:43 PM #52
Here is a video of it running and driving with 5spd goodness. I need to install the exhaust and replace the intake manifold gasket its leaking boost. And it need the rear nitrogen canister replaced badly
This post was last modified: 10-03-2015, 06:46 PM by willbhere4u.
Keino
10-04-2015, 03:17 AM #53
Using 3.46 differential?
Smile
Keino
Smile
10-04-2015, 06:08 PM #54
Its a stock diff from the automatic 1984 us spec car.
Today I installed the euro front bumper to finish off the front end of the car
This post was last modified: 10-04-2015, 06:27 PM by willbhere4u.
10-04-2015, 11:03 PM #55
The rear diff ratio is either 3.07 or 2.88
08-29-2018, 11:14 PM #56
Update just got car running again i just replaced the power stearing return hose and huydraulic feed hose for the sls rear suspention no more leaks next new motor mounts brakes all around the. Tires alignment a few new gauges and some euro interior goodness to come ill try and update some pictures soon maybe a video
08-30-2018, 04:33 PM #57
I just swaped both motor mounts today and will be pulling the oil pan to replace the oil pick up screen as last time i had the pan off the pick up was missing so i orderd a new one. Updade no more leaks at least while its sitting now so thats a win next project brakes  and tires. I really want to find a nice set of pentas for it and the AMG front air dam just got to pinch some pennys for awhile
This post was last modified: 09-05-2018, 06:36 PM by willbhere4u.
09-05-2018, 08:10 PM #58
Quick update here is a video i made
https://www.youtube.com/watch?v=d8p6G9If...e=youtu.be
09-07-2018, 07:09 PM #59
I just received the glove box from Macedonia and the rest of the dash trim from Uzbekistan going for that full euro interior look
 6 Guest(s)
 6 Guest(s)
