increase injection pressure om605
Hi,
since i want to keep my stock elements (6mm) and max out the pump to it´s maximum i thought about increasing the injection pressure for shorter injection times to lower my egt´s. Is that possible at a w202 250 td? And how can it be done? Via Remap or manual?
only thing u can do in that istallation , is incresse injector pop pressure, from 135BAR to what else u consider to be a good thing for u...
usually people use 150BAR. but i´m not so sure of benefits.... despite i have mine in that range too.
if u have EGT problems with a 6mm pump, something is very wrong, that can only mean 2 things engine is running outside timing or u have massive EGP ... if i were u i would start that road...
u still using the EDC pump?
no ... high is when u reach 1000º Hill climbing ....
yes is a kind of high for what a 6mm pump can do , something is wrong there...
check your camshaft timing , and pump timing(theres no reason to use the pump too much advancedaround 13º/14º is ok)... if all is ok then u have massive back pressure , u should find another turbo hehhe or exaust hhehe
this is my opinion and only my opinion... take as it is
regards
Ps: i´m assuming u have a decent charge cooler !!! clean intake dada those things
(10-26-2015, 04:06 AM)barrote ...u have massive back pressure , u should find another ... exaust.....
