OM603 Turbo
OM603 Turbo
Hi i recently got w124 with a om603 turbo and i was wondering if there are any turbos that i could swap on it without changing anything that comes stock on the engine. Im not looking for much just a little more power then stock and something that spools pretty quickly since its mostly just a daily driver. Thanks
If your manifold looks like this, then you have the trap ox delete manifold.
If it doesn't then you have a lot of T3 flange options
(11-05-2015, 09:19 AM)raysorenson If your manifold looks like this, then you have the trap ox delete manifold.Well good news it doesn't. Does this mean pretty much any t3 flange turbo can fit on?
Yes, as long as there's clearance between the frame rail and the manifold. Congrats:-)
(11-05-2015, 09:21 PM)raysorenson Yes, as long as there's clearance between the frame rail and the manifold. Congrats:-)
(11-05-2015, 08:12 AM)awsrock A 55 trim T3 from a 350sd will swap right in.
I just put an HX30 in my car with trap ox manifold, it was a real pain to get in but it fits, just need to make an adapter to the exhaust
I think you'll be much happier with a 90cc 7.5mm pump on an otherwise stock motor than with any turbo upgrade using a stock pump.
(11-10-2015, 08:29 AM)raysorenson I think you'll be much happier with a 90cc 7.5mm pump on an otherwise stock motor than with any turbo upgrade using a stock pump.
The best you'll get from a new turbo with the stock pump is a different power curve, maybe like 5 hp from a better flowing turbine and cooler egts, but with stock fuel it probably makes little difference. I can say the HX30 is making more power down low for sure, but I mostly did it for future upgrades / for fun. Cost wise, yeah, a new pump will have the biggest effect by far, you just need to keep an eye on EGTs if you are going to run the stock turbo- they are only good up to 18-20 psi. Not sure what dieselpumpuk costs, but dieselmeken is probably the biggest supplier. I think DPUK might use his pumps / elements. Also, Ray got his from Diesel Injection Systems in California which is an "approved" dieselmeken shop in the US - might save some money on imports / shipping. Price is pretty close though between the two.
