STD Tuning Engine Twin turbo - Big Backpressure?
deviance
HE351VE
88
11-03-2015, 07:24 PM #1
Hello!
Can it be problem is the small turbo is just too small and causing too big backpressure?
It's about GT20wg size.
Thanks!
deviance
Hello!
Thanks!
whipplem104
11-03-2015, 09:42 PM #2
Well since no one else is going to. Yes.
whipplem104
11-04-2015, 03:25 AM #3
what twin turbo app u have ? in a 603 right?
deviance
HE351VE
88
11-04-2015, 06:08 AM #4
606
Small turbo like gt20 big turbo is k27
deviance
606
AlanMcR
mind - blown
400
11-04-2015, 01:48 PM #5
That would be a sequential turbo, no?
AlanMcR
11-04-2015, 03:38 PM #6
hey man, u are walking the wrong road, have two gt20 one for each trio of cylinders, choose the ones that fire 120º appart.
0 /120/240, the other 60/180/300~
good luck then ...
good luck then ...
deviance
HE351VE
88
11-04-2015, 04:51 PM #7
This will be a big fail Sad
deviance
11-04-2015, 05:26 PM #8
(11-03-2015, 07:24 PM)deviance Hello!
Thanks!
If you mean compound then you need a big enough wg to bypass the small turbo as it becomes a gas restriction at high rpms
Thanks!
deviance
HE351VE
88
11-04-2015, 06:29 PM #9
I have like this so i can turn off the exhaust gas from small turbo.
pic
deviance
pic
Tito
11-05-2015, 04:00 PM #10
I was going to do the same thing. How did you route the exhaust side? The butterfly valve you showed should block off the big turbo and not the small one, so when the big turbo is needed the valve opens and lets the big turbo breathe.
Tito
11-06-2015, 04:59 AM #11
(11-05-2015, 04:00 PM)Tito I was going to do the same thing. How did you route the exhaust side? The butterfly valve you showed should block off the big turbo and not the small one, so when the big turbo is needed the valve opens and lets the big turbo breathe.
Problem is when that valve opens all drive pressure will fall to zero and boost will fall with it and you get a big step in the power curve and big puff o smoke.
I couldn't really work out how to control staging like that mechanically ie lots of actuators and flappy things (the onus being on not using electronics).
Perhaps the small turbo wastegate feeds the big turbo to start it spooling before flappy opens?
deviance
HE351VE
88
11-06-2015, 06:12 PM #12
We are not using electronic now and wastegate and i tested today it going really good!
deviance
 8 Guest(s)
 8 Guest(s)
