STD Tuning Drivetrain m110 flywheel idea
m110 flywheel idea
m110 flywheel idea
Syncro_G
0-60 in 29 sec
280
11-08-2009, 07:08 PM #1
A lightbulb went off over on one of the G-wagen sites and I thought I'd run the idea by you guys in case it's been done or there's known reasons not to do it.
the idea:
get an M110 flywheel and clutch (bigger, heavier duty clutch but less weight)
machine a steel ring to fit on top of the outer lip of the M110 pressure plate to give it more rotational mass.
pros:
quite a few G-wagen guys are swapping out their M110's for 617s. most came stock with 4-speed manual trannies but they are switching over to the sedan automatic because of the high cost and scarcity of G- clutch parts. so finding a way to reuse the M110 clutch seems pretty cool to me.
cons:
It seems pretty straight forward but machining the ring may not be that easy. it would need a pretty big lathe. Would have to figure out where to source the chunk of iron too. maybe a cut from a pipe of the right diameter that is then milled to spec.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
the idea:
pros:
cons:
'75 240D 4-Speed
11-08-2009, 07:39 PM #2
Why not use a 240D flywheel and M110 clutch? It will take a LOT of weight to get it even close to a 240D's mass.
M110:OM616:OM617
The 617 FW weighs 38lbs and the 616 about 10lbs less.
Also, as seen in the second picture, if you make a ring it will have to clear the starter nose.
This post was last modified: 11-08-2009, 07:40 PM by ForcedInduction.
M110:OM616:OM617
Syncro_G
0-60 in 29 sec
280
11-08-2009, 08:07 PM #3
(11-08-2009, 07:39 PM)ForcedInduction Why not use a 240D flywheel and M110 clutch? It will take a LOT of weight to get it even close to a 240D's mass.
I'm told the 240D clutch isn't strong enough for the weight of the G-wagen. the 300GD clutch is a bit bigger and the M110 clutch is bigger yet.
(11-08-2009, 07:39 PM)ForcedInduction Also, as seen in the second picture, if you make a ring it will have to clear the starter nose.
that shouldn't be hard - I'm thinking the ring would sit direclty on top of the pressure plate and use the same bolt holes to hold it on like a sandwich
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
11-09-2009, 02:28 PM #4
Whats the point of the M110 clutch if the diameter is the same? Are you sure its not just the clamping pressure of the pressure plate? I have the 23CM gwagen setup.
Syncro_G
0-60 in 29 sec
280
11-09-2009, 02:41 PM #5
(11-09-2009, 02:28 PM)winmutt Whats the point of the M110 clutch if the diameter is the same? Are you sure its not just the clamping pressure of the pressure plate? I have the 23CM gwagen setup.
I was assuming the M110 clutch was bigger but I haven't measured yet (I have one but it's not separated from the engine yet).
But the more I think of it, the more it seems like an iffy idea.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
11-09-2009, 06:44 PM #6
AFAIK there are only 2 sizes during those years, 21cm and 23cm. I have the 23cm setup which is great for low rpm higher torque operations (getting up on the ramps has never been easier). Otherwise I would just stick with the 21cm setup, there are a variety of pressure disks with different pressures which should be more than adequate for anything you can throw at it.
Syncro_G
0-60 in 29 sec
280
11-11-2009, 11:55 AM #7
thanks to both of you for swiftly dealing with that idea. On to better ones...
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
