STD Tuning Engine 648 oil pan on 606 questions
Grecy
12-04-2015, 12:10 AM #1
Hey everyone,
I've got the rear-sump oil pan from the 648 on my 606, and have two questions.
1. The dipstick tube from the 648 has been installed (near the back of the block, intake side) and I'm wondering if I can leave a dipstick in there while the engine is running, or if I must remove the dipstick when the engine is running? I have a generic dipstick that fits well enough.
2. There is a large opening in the pan at the rear, where the flywheel is visible.
I circled it in red in this image: http://imgur.com/qOtnL75
Is there a cover or rubber plug for that? I really don't want to pickup mud/stones in there.
Thanks,
-Dan
Grecy
Hey everyone,
Thanks,
-Dan
AlanMcR
mind - blown
400
12-04-2015, 12:33 AM #2
Look the part number for the pan up in the EPC. It will bring up a diagram with the pan, the plug and it's part number.
AlanMcR
Grecy
12-04-2015, 02:16 AM #3
(12-04-2015, 12:33 AM)AlanMcR Look the part number for the pan up in the EPC. It will bring up a diagram with the pan, the plug and it's part number.
How do I look something up in the EPC? I don't have any access to anything Mercedes.
Thanks,
-Dan
Grecy
Thanks,
-Dan
50harleyrider
GTA2359VK
397
12-08-2015, 07:18 AM #4
Curious about that also. Is it a web site like W124-zone.com? Grecy, did you use the oil pump,pickup tube and special main bearing bolts to secure the pickup tube?
50harleyrider
50harleyrider
GTA2359VK
397
12-08-2015, 07:19 AM #5
Curious about that also. Is it a web site like W124-zone.com? Grecy, did you use the 648 oil pump,pickup tube and special main bearing bolts to secure the 648 pickup tube? Know any good sources?
50harleyrider
hooblah
12-08-2015, 02:42 PM #6
Anyone know the torque specs for main bearing bolts?
hooblah
12-10-2015, 10:25 AM #7
(12-08-2015, 02:42 PM)hooblah Anyone know the torque specs for main bearing bolts?
I have a W202 C250TD Haynes manual I can consult for you on that.
gary andrews
4x4 builder
48
12-10-2015, 01:56 PM #8
think there 60nm and 90 degs
c250 std at mo
gary andrews
c250 std at mo
12-10-2015, 04:56 PM #9
(12-10-2015, 01:56 PM)gary andrews think there 60nm and 90 degs
