606 Front Pulley Pickup
Hi Guys,
I'm after a pick-up to get an RPM signal using a multiple of 0.5/1/2/3 to the crank.
As far as I can work out, the CPS uses 6 timing pips. So no use.
I've noticed on the front pulley, there is a pick-up. On the timing mark bracketry above the timing marks on the pulley, there's also an empty hole and a peice of threaded bar which looks like it may be designed to hold a sensor, maybe on another engine which the same pulley is used on.
Does anybody know which this is and the sensor used for pickup?
Kinda looks like the sort of sensor seen below the Yellow arrow on the pic!
It should be for checking TDC ? This engine looks like M103.
This sensor is not used. M103 has 3 timing marks on flywheel and sensor mounted through block.
