STD Other Projects om606 w123 project
om606 w123 project
om606 w123 project
brianom606
01-14-2016, 05:56 PM #1
[Image: 20160114_164351_zpsxgjldyt1.jpg]
brianom606
brianom606
01-14-2016, 05:57 PM #2
[Image: 20160114_164445_zpsinsh5ueq.jpg]
brianom606
brianom606
01-14-2016, 05:58 PM #3
[Image: 20160114_164413_zpsydpl1n2h.jpg]
brianom606
brianom606
01-14-2016, 05:59 PM #4
[Image: 20160114_164424_zpspkiixesv.jpg]
brianom606
brianom606
01-14-2016, 06:03 PM #5
I also licked up a 1999 e300td with 120k miles on the engine
[Image: FB_IMG_1452812465892_zpsw1zwrmla.jpg]
brianom606
brianom606
01-14-2016, 06:05 PM #6
The plan is to fit the engine with eletronic ip from the 606 with a chipped ecu and a bigger turbo also plan on useing the auto gearbox with a controller of some sort
brianom606
SurfRodder
Jackass Extraordinaire
611
01-16-2016, 11:47 PM #7
For engine control check out this:
http://www.superturbodiesel.com/std/show...p?tid=6975
and tranny:
http://www.superturbodiesel.com/std/show...p?tid=3701
both of these should help out with wiring and control significantly...
I think the w126 OM603 mounts should also work nicely for this conversion. I have a set I got a few years back (new) on ebay when I was considering installing a 603 in my w123. I have not yet attempted that project, but I have heard the engine mount points on w123 and w126 are really close, something like 1/2" plate spacer close. I'll look thru my old notes to see if I have part numbers available.
edit:
Left bracket: 6032230604
http://www.ebay.com/itm/Mercedes-Benz-OM..._386wt_955
right bracket: 6032230704
http://www.ebay.com/itm/Mercedes-Benz-OM..._454wt_955
This post was last modified: 01-16-2016, 11:52 PM by SurfRodder.
OBK# 62
SurfRodder
and tranny:
edit:
OBK# 62
soltysrsz
01-17-2016, 02:18 AM #8
If you want use om603 w126 motor mount you need to made this spacer :
https://goo.gl/photos/PwfynkRQdnRiDfps8
https://goo.gl/photos/dJwYynemGEVmvDfS7
I have enough clearance to mount original fan Wink, you can move engine more to back, but you need to cut oil pan:
https://goo.gl/photos/27SEXVgihzcJLBGXA
Mercedes W123 240D (om616->om606)
Audi A6 C4 2,8 Quattro (AAH)
EX Audi 80 Competition
EX Ford Scorpio 2,9 4x4
soltysrsz
brianom606
01-17-2016, 06:22 AM #9
(01-16-2016, 11:47 PM)SurfRodder For engine control check out this:
and tranny:
edit:
Thank you that helps alot i was not sure weather it was petrol or diesel mounts i needed go use ....
Im going to  be testing a ecu with a chip a lad here in ireland made to run the engine ... and i will have to buy a gearbox controller or get a c220 cdi 6 speed
brianom606
and tranny:
edit:
brianom606
01-17-2016, 06:24 AM #10
(01-17-2016, 02:18 AM)soltysrsz If you want use om603 w126 motor mount you need to made this spacer :
Have u any pictures of your conversion ?
brianom606
soltysrsz
01-17-2016, 07:09 AM #11
here you got my pictures:
https://photos.google.com/share/AF1QipNg...RyZFRsc1VB
soltysrsz
brianom606
01-17-2016, 05:19 PM #12
Cool alot of work in them
brianom606
