STD Maintenance General Afterglow relay for 606
SurfRodder
Jackass Extraordinaire
611
10-11-2015, 12:54 PM #1
Hello all. I am ordering parts to upgrade glow system to afterglow on my wagon in preparation for the 606 swap.  I see that Huco crossreferences 0155453032 with their 13 2037 part.  Does anyone know if that P/N actually refer to a 180 second afterglow relay?  I seems like that part # is 1/3 - 1/2 the cost of others. anyway thanks in advance!
OBK# 62
SurfRodder
OBK# 62
erx
w202 om606
323
10-11-2015, 01:42 PM #2
Hi, I have that exact Huco relay and it has 15 second afterglow, yes 15 not 150 or 180. It is working fine but when I bought it I also thought it has 180 second afterglow.
This post was last modified: 10-12-2015, 03:00 AM by erx.
erx
SurfRodder
611
10-12-2015, 09:51 AM #3
Awesome, that is exactly what I needed. Thanks for the info. I had ordered one but decided to cancel it on a hunch it was improperly crossreferenced. Ill get one with the proper MB part number on it. Thanks again!
OBK# 62
SurfRodder
OBK# 62
erx
w202 om606
323
10-12-2015, 10:42 AM #4
If you look for used relay then make sure it is switching all 6 plugs, I have two relays with one connecting bridge burnt down so one glowplug will not work with it. It seems to be quite common problem.
[Image: IMG_5023_zpsf6e98310.jpg]
This post was last modified: 10-12-2015, 10:44 AM by erx.
erx
SurfRodder
611
03-04-2016, 10:20 PM #5
(10-12-2015, 10:42 AM)erx If you look for used relay then make sure it is switching all 6 plugs, I have two relays with one connecting bridge burnt down so one glowplug will not work with it. It seems to be quite common problem.
interesting...thanks for the info.  I ended up getting a new one, but now it's in storage awaiting a move.
OBK# 62
SurfRodder
OBK# 62
