STD Tuning Drivetrain MB Autobox compatiblity
ho55
03-11-2016, 08:28 AM #1
Any MB gearbox experts here?
I have an OM606.962 with a 722.6 box. (From a E300 W210)
But i am considering finding a 722.x box from a ML270 W134 2.7 CDI
I already changed the sump to the E320 type.
Do you think i will need to change the bell housing? Or will that now fit the 606 and the 320 sump?
If i have to swap the bellhousing from the 722.6 to ML box does that work? Is it a big job?
What about the torque converter, which will fit?
This post was last modified: 03-11-2016, 08:29 AM by ho55.
ho55
ross
03-14-2016, 05:15 PM #2
Interested to know! I assume the sump is the rear bowl type?
ross
erx
w202 om606
323
03-14-2016, 05:25 PM #3
270CDI has the same bellhousing as 300td, but I think that sump bolt holes to gearbox will not match. 300td and 270CDI have the same size converter, both will fit.
erx
