STD Other Projects Beater w116 project
Beater w116 project
Beater w116 project
Dark Hawk
02-27-2016, 02:45 AM #1
This is my w116 I bought a couple months ago for $500. 220k, mint interior,good brakes, GREAT running om617, and other the creacher comfort crap is basically broken. Just what I want! I plan to base my build off of dieselboys w116 and the captain's w123
Plans to come
Alda (obviously)
Fender pipe  Tongue
Cut coils, probably 3 front 2 rear. I know that's a good deal
Upgraded turbo, probably hy35
Intercooler, yes I really will
Injectors, reasearch will determine which
Rack limiter
Welded diff
Delete: AC and powerstearing. Neither work so who cares
Maybe a cheap light bar just for fun
This post was last modified: 02-27-2016, 02:49 AM by Dark Hawk.
1984 300d 132k restormod project in the works
1985 300td 300k $600 off road adventure project
1999 land cruiser  235k, 33" mud tires, off road, towing, hauler
Dark Hawk
Plans to come
Alda (obviously)
Fender pipe  Tongue
Rack limiter
Welded diff
bricktron
'77 240D
174
02-29-2016, 12:27 AM #2
that will be fun with no PS. sounds heavy duty.
bricktron
02-29-2016, 10:04 PM #3
I think the biggest problem with the no PS sourcing a manual box. But it sounds like a fun build.
Dark Hawk
03-02-2016, 09:21 PM #4
Ah, it will be fine once I get it rolling, but ya parking lots won't be fun between the no PS and a welded diff  Big Grin .
Like I said this is a fun beater. It won't be a daily so driveability is not important. Really only going to be driven for joining or when I'm working on my other cars.
Because of this I have done a bit of additional reading and have found a few people hacking up delivery valves to increase fuel flow. My question is how well does this work and how do you do it? Btw m pump is out of the budget.
Also I can't figure out how to post pics.
Dark Hawk
03-02-2016, 11:17 PM #5
I haven't heard of anyone cutting delivery valves and getting successful results yet. Theses DV don't have a collar on them like a P-pump from a cummins does. If you don't want to spend the $$ on a big plunger pump, turning up your stock pump will be the best bang for you buck. It'll net you about 150hp, maybe a tick more,Maybe less. My car dyno'd at 125 at the wheels with everything in my sig, so that's about 150hp considering driveline loss.
Maybe another forum member with more MW DV valve knowledge can chime in.
As far as pics, I upload to photobucket then resize and copy the url into the picture thingy. I'm not sure if there is a post requirement before pics or not.
Dark Hawk
03-03-2016, 12:48 AM #6
I got the delivery valve idea from here, http://www.superturbodiesel.com/std/show...p?tid=3644
Another build I'm taking inspiration from. Any thoughts?
Dark Hawk
03-06-2016, 12:28 AM #7
Considering people that build injection pumps for a living will tell you that a stock mw will only put out about 60cc full adjusted, 200hp is a laughable estimate. I've seen where people do the math, and 60cc is only enough fuel for 160-170hp at best. Something about the thread just doesn't seem right...
I'm not saying it's made up, but I'm skeptical.
Dark Hawk
03-06-2016, 02:14 PM #8
That's also what I was thinking, wishful thinking on my part thinking I could get around needing an m pump lol
Dark Hawk
03-06-2016, 03:41 PM #9
I am still hopeful for the 10mm MW, there's no such thing as an injection duration that is too short, the bigger the better! M-pumps are hard to find and having to send them overseas to get worked on is costly, even though I am a firm believer that it doesn't get much better than dieselmeken when it comes
To Mercedes pumps
To Mercedes pumps
EmJay
03-06-2016, 07:57 PM #10
Instead of a welded diff, why not find an LSD diff and put it in?
EmJay
NZScott
HX30W 73/44mm
398
03-06-2016, 11:59 PM #11
LSD's that fit are a bit price prohibitive
http://www.ebay.com/itm/Mercedes-Benz-W1...to&vxp=mtr
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
Dark Hawk
03-07-2016, 04:47 PM #12
Exactly, even if I could afford it I still wouldn't buy it being that the idea behind this project is the most performance possible with the least amount of cash. If I were to do an LSD it would be on my other project, but that's probably not going to happen unfortunately.
Dark Hawk
DrewGerhan
101
03-09-2016, 04:29 AM #13
(03-02-2016, 09:21 PM)Dark Hawk Ah, it will be fine once I get it rolling, but ya parking lots won't be fun between the no PS and a welded diff  Big Grin .
I cut a spare set I had a few years ago. It was the best I could do I'm my garage, but I think it was fairly accurate.
That being said, don't do it. It wouldn't return to idle at all after that. Had to swap back in the stock ones. I think I've got a video somewhere of it in the car.
Here ya go.
https://youtu.be/Y4zVv2eZ0ig
DrewGerhan
Here ya go.
Dark Hawk
03-13-2016, 01:55 PM #14
How by it wouldn't return to idel do you mean that it would idel really high, hunt for rpm, or die without some throttle? Because that doesn't seem all THAT bad for a non daily.
Dark Hawk
03-13-2016, 02:14 PM #15
You can see in the vid he posted that it takes about 45seconds to go from 3k down to idle lol, that would be bad.
Dark Hawk
03-20-2016, 01:20 PM #16
https://flic.kr/p/Fkywrn
https://flic.kr/p/Fkywo6
This post was last modified: 03-20-2016, 01:22 PM by Dark Hawk.
Dark Hawk
03-20-2016, 07:05 PM #17
It's got euro bumpers on it, Nice!
Dark Hawk
03-23-2016, 07:56 AM #18
I thought it was the American bumpers that were the size of diving boards lol.
Dark Hawk
03-23-2016, 07:33 PM #19
I think those are euros, I could be wrong though
03-24-2016, 04:29 AM #20
They look like standard US spec bumpers to me
03-24-2016, 12:30 PM #21
Blush  Duh, I forgot it was a w116. I'm too use to the w123 body style I guess
Dark Hawk
03-24-2016, 01:30 PM #22
They might be ugly, but I do like how it's basically a bull bar. You can run into anything and it don't give a fuck!
I'm thinking of painting the car a matte od green with metalic bronze wheels. You guys think that would look good?
Dark Hawk
Dark Hawk
04-30-2016, 09:26 AM #23
I did a diesel purge a couple days ago and it made a big difference. I did one in the past in tandem with a valve adjustment and it made a HUGE difference but the valves were way out of tune so I didn't really know which was more effective form of of performance enhancing maintanence. I'll be doing a valve adjustment tonight to compare the two.
Dark Hawk
Dark Hawk
05-09-2016, 12:18 PM #24
Did the valve adjustment and I'm guessing the valves were adjusted by the previous owner because they really weren't too bad at all. I saw no real "gain" in power though idle seemed a super tiny bit better.
The biggest hinderence on the 0-60/quarter mile/ acceleration in general seems to be the transmission. It shifts perfectly smooth, just really slow. Anyone have ANY suggestions?
Also an exhaust and Alda will be coming shortly
Dark Hawk
05-09-2016, 11:36 PM #25
Alfa removal/ adjustment will help tremendously.
Also, have you turned up the line pressure on the trans? Helps to firm up the shifts. My is cranked up a lot, it almost bangs when it shifts. But whipplem said they are tough and like a lot of line pressure, so I gave it to it
