STD Tuning Drivetrain om603 turbo what used clutch ?
jarow123
08-12-2016, 02:47 PM #1
I have om603 turbo with 370nm with stock cluth , the question is with which the clutch sitting there, some strong, manufactured by Mercedes? or I only use ceramics cluth ? ?  Confused
jarow123
F.R.A.S
08-18-2016, 03:50 AM #2
Get a flywheel and pressure plate from a 270cdi Smile That should be fine for a while. If that slips get a sinter-clutch for the same setup.
F.R.A.S
JoeB
08-19-2016, 06:50 PM #3
(08-12-2016, 02:47 PM)jarow123 I have om603 turbo with 370nm with stock cluth , the question is with which the clutch sitting there, some strong, manufactured by Mercedes? or I only use ceramics cluth ? ?  Confused
What gearbox do you have behind your OM603 and what vehicle is it in?
JoeB
