OM603 or om606 Injection timing with timing light adapter
There is plenty of info about setting the injection pump timing with the drip method or other methods, but I can't seem to find much info about using a timing light with an adapter clamped on the #1 injector line.
I seem to recall 12 degrees BTDC was what to expect at idle using a timing light adapter. I cant find that info anymore.
Does anyone have experience with this? I bought an adapter, so if anyone in the Seattle area wants to know what their timing is let me know.
I think that one should not compare static advance at 0 RPM and the advance at 800 RPM. During running, the timing device advances because of the rotational speed, and the pump elements can have influence on advance too, if they are rotated by the rack ( I am at this point not sure whether they are, still need to read books).
Therefore these " 12 Deg BTDC" in static drip-test are for sure not (perfectly) valid for a test on a running engine...
(please correct me if I'm wrong).
YET, there must be some kind of reference value what it then should be! But, where to find it ?
lalalla
set to read OT at crank, and the box should give u 18º , engine at idle. MB says to use between 16.5 and 17.5 , then test set the value and dadadda of course this is with the MB recomended timing light device.
with something else u have to consider the delay in the info pick up... basically set yur own box...
regards
I checked an OM617 that was rebuilt 3,000 miles ago and timed with the drip method. With my Sealey timing adapter it was reading 15-16 degrees BTDC, but he added 3 degrees when he timed it so it would have been 12-13 degrees.
Of course the injector line clamp was too big for my 603 lines, so I have to get a different clamp before I can check my 603.
never mind ,
The installation timing is just to set the engine in condition of operation, even if u tune by the drip method, then u got to tune more on listening and using if u want to guet the right position for "start of injection".
For instace, if u have a slight deviation on the crank puley u can have a engine retarded or advanced by 2 or 3º , its something common, like the pump timing device , "lock positio" is set by the pump builder and again u can have a offset of 2/3º. So dont be surprised if u find a engine running good with 23º BTDC ...
Here we use the mb recomended tool wich is stanadyne brand. And we usually set for 17 to 18.
Stock engines and all of them. Other engines apart frm mb have other methods. Mb's STD's is a diff story, 18 is to start
Then it might be necessary to decrease or increase.
Regards.
After lots of searching I still have not found any clamp that fits the OM606/OM603 injector lines. They are ~4.6mm outer diameter. OM617 lines are 6mm.
So I machined a sleeve that fits over the the line and hopefully will hopefully let me to finally check injection timing.
I'm checking timing because my low end power seems a bit sluggish and timing would be the easiest fix.
I haven't found anyone else posting numbers using the clamped injector line method. I measured a friends om617 and it ran right around 14 degrees BTDC. That was after adding a couple extra degrees using the drip method. That's a different engine and a completely stock injection pump.
Dieselmeken has confirmed that 18 degrees seems about right, but I still don't have any other numbers from people using this timing method.
