STD Tuning Drivetrain 722.6 Output flange shims
matfield
11-28-2016, 02:36 PM #1
Hi,
Can some one tell me the part no. or dimensions of the output flange shims on the 722.6?
Also does anyone have and EPC drawing of where they go in relation to the output flange, and the output flange nut; i.e. before the flange, or between the flange and nut?
Thanks
Mat
matfield
Hi,
Thanks
Mat
Evgeniy1987
11-28-2016, 03:55 PM #2
[Image: det_expl_920_1.jpg]
Would this help you ?
Evgeniy1987
matfield
11-28-2016, 04:03 PM #3
That looks good... by the looks of things there, the shims I'm after are #270, this seems to be behind the oil seal and a circlip though, is this correct, or can the shims be pulled out when the output flange is removed?
The reason I'm asking is I have quite a lot of play in the rear output flange and was hoping i'd lost a shim when having it machined.
matfield
matfield
11-28-2016, 04:42 PM #5
That answers all the questions... Thanks Sultzi. According to Page 39, the shims can't just fall out, the Circlip would have to be removed, so I'll check the bolt again, and make sure its tight.
Thanks for the replies!!
Mat
matfield
Mat
