STD Tuning Drivetrain ways to put w124 speedometer work whith 6 speed gearbox
PedroFerreira
11-09-2016, 01:39 PM #1
hello,can some one tell me what´s the way to put speedometer working whith 6speed from w203?
PedroFerreira
firen456
11-10-2016, 08:53 AM #2
Hello,
use the speed sensor from the diff with a speedohealer V4. I got issues with the signal of the sensor and solved it by converting the sensor signal to a square signal with a lm1815. It works great now. With the speedohealer you can adjust vour tach signal from -99.9% to 9999,9%.
firen456
Hello,
hansdampf
01-10-2017, 12:59 PM #3
Hi firen,
could you give more information of how to connect the lm 1815. I have a speedo healer v4 in connection with a german device the converts a wave signal into a square signal. Deppending strongly on the the temperature (the colder, the better it works …) the speedo (w126) falls back to zero at max 170 km/h …
I think the signal converter I have does not wotk right.
Should be 4 wires. +, ground signal-in and signal out … right?
Please help me out,
how do I connect the lm1815?
cheers from munich
hansdampf
hansdampf
Hi firen,
Please help me out,
cheers from munich
hansdampf
Tobulus
01-11-2017, 09:07 AM #4
I know that problem. The speedometer is built to work with an inductive sensor, square signal input doesnt work above a certain frequency.
Tobulus
firen456
01-13-2017, 02:49 PM #5
Hi,
in the LM1815's datasheet there is a circuit explained which works well.
There's a german whatsapp group i want you to join Smile   Just PM me...
Max
firen456
Hi,
Max
Gelubelea
01-15-2017, 08:24 PM #6
Better conditioning the signal with NCV1124 or MAX9924
Gelu
Gelubelea
Gelu
hansdampf
02-03-2017, 04:20 PM #7
(01-15-2017, 08:24 PM)Gelubelea Better conditioning the signal with NCV1124 or MAX9924
Gelu
Maybe you are so right as many ways lead to rome …
Hi firen,
thx a lot for helping me out so much.
That was bad ass ….
I was so enthusiastic about your work, that I forgot about … Angel (HX 40)
Sevus fo Minga und bis zum nexscht´n moi, Du gacher und wuida Hackler!!!
dei
Andi
hansdampf
Gelu
Hi firen,
That was bad ass ….
dei
Andi
PedroFerreira
02-03-2017, 06:50 PM #8
hello someone can help me instaling the speedohealer?
PedroFerreira
firen456
02-04-2017, 09:27 AM #9
Measse Smile oiwei wieder gern...
In the attached pictures you can see where to take and how to modify the signals. Dont't ask me where you can find which wire exactly. I Don't know. The ABS-Sensor is plugged under the rear seats and the ABS control unit can be found behind the Battery in W124.
firen456
PedroFerreira
02-04-2017, 01:15 PM #10
firen i send you pm
PedroFerreira
firen i send you pm
PedroFerreira
02-04-2017, 05:57 PM #11
can i conect the speedohealer directly to abs sensor?or i whill nedd the amplifier?
PedroFerreira
JoeB
02-12-2017, 03:04 AM #12
There are several threads on this. please use the search function.
If you want to use a hall-effect sensor then use the v4.
For information use:
https://www.healtech-electronics.com/products/sh/
If you MUST use an inductive sensor (diff/abs) then you need the special SH-V4-2W version.
 SpeedoHealer special models
JoeB
PedroFerreira
02-12-2017, 11:11 AM #13
Joeb if i use SH-V4-2W dont have to use lm1815? is just plug and play?
PedroFerreira
JoeB
02-12-2017, 07:48 PM #14
Correct.
JoeB
Correct.
