Crankcase vent into turbo
Just complcompleted the HX30W instinstall with intercooler on my om617. I have elimeliminated the factory air filter along with the oil condenser from the CCV. Question is can I run the hose directly back into the turbo compressor and right back into the combustion chamber. It is my understanding that priprior to 78' EPA this is how it was done.
This is how I have my on my non performance cars. I think for performance it would be ideal to not send crankcase gas through motor but I dont know how much it would hurt.
You don't want to do it on a gas burner because oil has an octane rating of about 30. The only reason not to do it on a diesel is that is something fails and allows too much oil to enter the turbo, the engine can run away. An oil separator device should be used, even if it's just a baffle below the hole in the valve cover.
(08-14-2016, 09:40 AM)raysorenson You don't want to do it on a gas burner because oil has an octane rating of about 30. The only reason not to do it on a diesel is that is something fails and allows too much oil to enter the turbo, the engine can run away. An oil separator device should be used, even if it's just a baffle below the hole in the valve cover.
Catch can and vent to atmosphere. Oil will probably pool in your intercooler?
Consider: Bypassing PCV to exhaust
http://forums.vwvortex.com/showthread.php?4387972
(08-14-2016, 08:01 AM)Evenglass Just complcompleted the HX30W instinstall with intercooler on my om617. I have elimeliminated the factory air filter along with the oil condenser from the CCV. Question is can I run the hose directly back into the turbo compressor and right back into the combustion chamber. It is my understanding that priprior to 78' EPA this is how it was done.
Use some good oil separator from actual engine. Those funny catch tanks have little efficiency with condensing oil mist into liquid oil and returning them into oil sump. Some engines of 90s era had vent directly into turbo inltet, there it has condensed in intercooler and intake was filled with oil. This oil also burned and residued on intake valves.. it is shit. For example oil separator from Audi 3.3TDI V8, pretty good centrifugal thing-one inlet for mist, one outlet into intake and down goes oil into sump.
The Mercedes factory separator in the air cleaner housing is of the cyclonic variety. I learned this after taking it apart. What I ended up doing was taking the top cyclonic portion of the factory Mercedes unit and inserted it into the top of a 1qt paint can, it dits perfectly. Then I'm going to run the vent out the back next to the exhaust pipe.
(08-15-2016, 03:54 PM)starynovy Use some good oil separator from actual engine. Those funny catch tanks have little efficiency with condensing oil mist into liquid oil and returning them into oil sump. Some engines of 90s era had vent directly into turbo inltet, there it has condensed in intercooler and intake was filled with oil. This oil also burned and residued on intake valves.. it is shit. For example oil separator from Audi 3.3TDI V8, pretty good centrifugal thing-one inlet for mist, one outlet into intake and down goes oil into sump.
Yes, could be.. or drill block and fit banjo or put banjo bolt with fiting instead of drain bolt on your sump (this was actually done on 2.5TDI)
dunno if I'd want to return my oil separator's condensate to the crankcase, it's more than half water
Last winter it has frozen solid, causing lots of oil to dump out the turbine ring seal, tons of white smoke until I smashed the ice and let the crankcase pressure out.
I'm just running the CCV hose stuffed into a coke bottle with the top cut off, all the way down to the bottom, then stuff in a bunch of fast food napkins around it so the gas has to percolate up through the napkins. Before I just had the breather open, but it'd coat the wipers in oil mist pretty quickly.
Crank case gases are also like EGR gases and we all know how good EGR is for performance. I dump mine out the back of the car.
most effective solution is PCV gasses direct to exhaust via non-return valve. Moroso have been making them for decades. Straightforward. Cheap. Effective. No recirculated shit in your engine. By all means consider an oil separator inline and return to sump, or not. How complex you wish to make it is entirely up to you.
(08-15-2016, 06:20 AM)Hario(08-14-2016, 08:01 AM)Evenglass Just complcompleted the HX30W instinstall with intercooler on my om617. I have elimeliminated the factory air filter along with the oil condenser from the CCV. Question is can I run the hose directly back into the turbo compressor and right back into the combustion chamber. It is my understanding that priprior to 78' EPA this is how it was done.
Yes but without the oil condenser you will be pushing oil mist into the turbo inlet?
I delete EGR but personally I keep crank case vent recirculating into the air inlet, it's marginal from a performance perspective but stick a filter on the cam cover breather and it will soon be dripping in oil and will cover the whole engine bay with an oil film which isn't nice..
(02-05-2017, 11:23 AM)bullonezero Here's my approach to itLooks really good. On my current engine the blowby was smokey and a little excessive so I had no choice but to have the engine eat it. I'm building an engine now with very little blowby and valve job, I may try this on it.
The Moroso valves are not MOT / DOT / EPA 'compliant' on any 'emissions equipped' vehicle. they were strictly for the pre1974 emissions standards.
If you want to return to inlet - aka a true PCV oil separator (not an EGR oil separator, there is a difference) then you can look into various 'catch-can' solutions.
EGR delete and a PCV oil separator to me are the most logical pairing, for a couple of reasons...
1. egr blanking plate prevents any exhaust gas ccontaminant introduction into the intake.
2. PCV oil separator removes any oil vapour form the intake, preventing it from clogging intercooler, and stops carbon soot buildup. It's been proven to reduce intercooler temps by 10ºC when correctly implemented.
The key is to make sure you use a separator with a proper filter and a large surface area / volume. The small ones are a complete waste of time.
In australia we have a local company that makes them - called Flashlube. They are used extensively in the 4x4 industry because they prevent all the engine damage from oil vapour - i.e. carbon buildup etc. They do sell them internationally. Not sure who your local agent would be though.
Have a read:
http://www.flashlube.com/en/products/catch-can-pro.html
(02-06-2017, 05:15 PM)Hario(02-05-2017, 11:23 AM)bullonezero Here's my approach to it
That is a dam neat solution!
Can you say if the Moroso valve is just a regular looking check valve with metal insides?
Can't see any for sale on our island,
Beers! HH
Beers! HH
(02-07-2017, 03:30 AM)hooblah Just run a pipe down to the ground beneath. Unless it's leaving puddles everywhere I wouldn't worry about oil on the road. This is what they did back in the day.
