STD Tuning Drivetrain 716.630 gear linkage mods
jhw.
02-09-2017, 02:43 PM #1
I have a 716.630 mated to an om605 that I've fitted to the car.
The big selector rod needs to be shortened by 10cm which is no problem.
I'm a bit stuck with the cable at the side, it only ever seems to move when Reverse on the gear selector is selected.
I have bought 4 linkages and the bit between the cable and box is missing on all of them  Angry
Any help, is the cable required?
jhw.
JoeB
02-12-2017, 03:29 AM #2
Yes, the cable is required.
On the end of the cable is an adjuster, although I doubt that with 100mm shortening you will be able to achieve this without shortening the cable itself.
the bracket on the side which receives the cable, runs through 2 pivot linkages and rotates through 90 degrees, to which a connecting rod joins the selector rod to the cable.
The purpose is to allow engagement of reverse and correct spacing of the H pattern, with the appropriate centre position.
IF the cable is not correctly set, the shift lever will make it all but impossible to select all gears. usually 5 & 6 go missing, because the cable prevents the full rotation of the selector arm.
This post was last modified: 02-12-2017, 04:06 AM by JoeB.
JoeB
juggs
02-14-2017, 07:39 AM #3
Has anyone got around this or found a suitable shorter cable?
In the middle of trying to do this 6 speed swap into a w202 myself but came up against a brick wall with shortening the cable.
juggs
juggs
02-14-2017, 07:39 AM #4
juggs
seanyt
is300d He351ve
279
02-15-2017, 10:54 AM #5
i cut the metal elbow off the cable to help with it.
I also got a small cable made up but the original with metal elbow cut off did a better job.
or look into the w204 shifter setup.
I may change to this when the gearbox is out.
Its a single bar that rotates for left and right instead of the cable section.
This post was last modified: 02-15-2017, 10:55 AM by seanyt.
seanyt
Max
Turbinaaa
87
02-15-2017, 05:26 PM #6
Hi,
if you fit a 716 Gearbox in an w201, you just take the Cable from an w208 CLK 230 with 6-Speed Gearbox.
Cost is about 30 € new at your local MB-Dealer.
Its a straigt bolt-on.
Greets
Max
This post was last modified: 02-15-2017, 05:26 PM by Max.
Max
Hi,
Greets
Max
bruno_pinho
02-16-2017, 03:03 PM #7
(02-15-2017, 10:54 AM)seanyt i cut the metal elbow off the cable to help with it.
I also thought about it and I wanted to do it...but
How can you solve the fitting problem in the gearbox,the fit is different for the 2 shifter in gearbox..?
bruno_pinho
juggs
02-19-2017, 02:08 PM #8
Max do you know if the clk 230 set up works for a w202 as well?
juggs
Max
Turbinaaa
87
02-19-2017, 03:41 PM #9
No, i only have expierence with w201.
Max
