W210 M104 flywheel question
Hey guys,
I'm trying to do my research on converting my US spec 1997 E320 with M104.995 to manual trans.
After research, I found out that the 6 speed manual from a M111 engine bolts straight up. SLK230 or C230 kompressor. Those are easily found here.
The only question is, what flywheel do I use? This will be a road car, no racing, no modding...so a dual mass is ok.
So I guess my question is, will the flywheel from the M111 bolt straight up to M104 and is it balanced and contains the 60-2 teeth for the CPS?
Any advice appreciated.
(03-24-2017, 01:22 AM)Deplore Anyone? I found posts elsewhere supporting the hypothesis that the M111 manual trans (flywheel, et al) from a manual car (SLK230, C230 kompressor manual) is a direct bolt on a M104 car?
Rennsport so a flywheel it needs 3 segments instead of 2 ran on the M111 (on the 5 speeds anyway 6 speed might be different). I don't the conversion but used a box with a smf (717.411) had to put the flywheel on a lathe and take off the width of the flex plate and weld the 2 together at tdc. Not sure if it can be done with a dmf
