STD Tuning Drivetrain 722.6 ML Class Gearbox output splines
ross
04-06-2017, 06:28 AM #1
Does anyone on here know the size of the output splines on an ML class version of the 722.6? Or know where I might find it?
Thanks in advance!
ross
Thanks in advance!
whipplem104
04-06-2017, 07:56 AM #2
are you asking about the transmission shaft or the output that bolts on??
whipplem104
ross
04-06-2017, 08:14 AM #3
(04-06-2017, 07:56 AM)whipplem104 are you asking about the transmission shaft or the output that bolts on??
The output that bolts on, the ~50ish mm diameter female spline.
ross
whipplem104
04-06-2017, 10:48 AM #4
Well normally you measure diameter and count the splines. So I would say it is 55mm 26 spline. It might be 54mm. I do not have my good calipers here today. Just used some brake calipers
Splines are really standard so you should be able to find the standard sizes
whipplem104
ross
04-07-2017, 01:50 AM #5
Yeah, but there are all sorts of shapes of spline, lots of different standards.
ross
whipplem104
04-07-2017, 08:00 AM #6
What are you trying to find out if it fits?
whipplem104
ross
04-07-2017, 09:07 AM #7
I need the original specification of the spline so I can have a spline machined to match it on my adaptor shaft.
ross
whipplem104
04-07-2017, 04:15 PM #8
Ok,
It is the same as the JEEP srt8 and the wranglers with the nv t cases. You might find more info looking for those.
whipplem104
Ok,
ross
04-19-2017, 08:08 AM #9
Thanks Whipple Smile.
I've actually contacted Mercedes UK, and I've had a response! Smile
ross
matfield
06-29-2017, 05:39 AM #10
Ross... would you have a measurement from bell housing to the rear output flange that bolts onto the Merc transfer box?
Thanks
Mat
matfield
Thanks
Mat
ross
07-04-2017, 03:47 PM #11
(06-29-2017, 05:39 AM)matfield Ross... would you have a measurement from bell housing to the rear output flange that bolts onto the Merc transfer box?
Thanks
Mat
The back face where the adaptor bolts on? There's a small link bit/adaptor on the ML box.
I haven't got the measurement to hand, but I can get it for you?
ross
Thanks
Mat
 8 Guest(s)
 8 Guest(s)
