STD Tuning Engine Turbo Suggestion for a OM602962
alesbm
12-05-2009, 03:59 PM #1
Anyone know a good turbo replacement for a OM602962 for a 250D turbo, it can be a vnt...
I m looking for Garett 2256V or someting similar,
The engine is in mercedes benz G end using for extrem offroad
end i need more torque in low renge
alesbm
12-05-2009, 04:35 PM #2
GT1852V, GT2052V, GTA2056V (Liberty), GT2256V (Sprinter) and GT2359V (E320 CDI) would be good matches. The 59mm compressor would be large until a modified injection pump is installed.
If off roading and extreme low end torque is your primary goal, a GT1852V or GT2052V would be able to produce 15psi at 2000rpm without surge.
The GTA2056V and GT2256V would allow much higher boost from 2500rpm to redline.
This post was last modified: 12-05-2009, 04:35 PM by ForcedInduction.
alesbm
12-06-2009, 03:35 PM #3
I prefere GT2052V (WV 2.5TDI V6 or GT2256V (Sprinter) because
is easyer to founded in Europa.
How to modified injection pump end the iniecion with thease new turbo???
The torque from 2500rpm to redline is OK.
alesbm
12-07-2009, 01:55 PM #4
2052 is too small. The 2359 is fairly common over there as is the 2059 etc.
12-07-2009, 09:04 PM #5
(12-07-2009, 01:55 PM)winmutt 2052 is too small.
Not for a 602. At 15psi it will be right at the max compressor speed at engine redline (at sea level).
A 2359 on a 602 for "extreme offroad" would be surging until mid-rpms.
alesbm
12-09-2009, 03:48 AM #6
I found a MB 320CDI turbocharger GT2056V, I hope that this is OK
alesbm
12-09-2009, 04:21 AM #7
If its a 2008+ model, its got a rear facing turbine inlet.
nazim
12-23-2009, 09:10 AM #8
(12-09-2009, 03:48 AM)alesbm I found a MB 320CDI turbocharger GT2056V, I hope that this is OK
Hello,
How is the result on your new turbo?
I also have OM602, 2.9 liter. I'm looking after a turbo to get more power at low rpm.
Please let me know if the application is successfull or not.
Thanks,
Nazim
nazim
Hello,
Thanks,
Nazim
