722.6 in a w124 help!!!!
Well I have decided to fit a 722.6 to my 300ce which has a om605 turbo fitted. My main questions are Is the 722.6 the same length as the 722.3 that is in the car at the moment.
My other question is are the output yokes interchangeable on the 722.6 A's the yoke on my donor box is bigger then the shaft in the car at the moment. The reason I am asking this that I had to get a custom shaft made as it is a coupe.
Thanks In advance folk
The 722.6 is about 3/8" longer. The driveshaft has enough play in it to take this up though. You can swap any 722.6 flange from any other. There are 90mm, 100mm, and 110mm 3 bolt flanges.
How is the flange measured? I am doing this swap right now and I cant tell which flange I have/need
It is measured by bolt circle diameter. Same as a wheel bolt pattern. So basically draw a circle through the center of the bolt all the way around like a compass. Measure that circles diameter. Generally you will have 90mm 100mm or 115mm 3 or 4 bolt bolt circles. Large AMG cars have 4 bolt 120mm.
