STD Tuning Engine Turbo boost Controller
Frank606
01-09-2018, 04:34 PM #1
Any one can Help
There is so much confusion and many applications on how to fit a Manual boost Controller combined with a boost vacuum gauge
I want to fit one of these for a internal wastegate set up
Any one can send me a simple Diagram on this set up would be great
Thanks
Frank606
Any one can Help
Thanks
Fishman
01-10-2018, 11:16 AM #2
Need more info. Original turbo has vacuum actuator.
Fishman
Frank606
01-10-2018, 02:03 PM #3
Hi
Thanks for your Reply
Turbo is a upgrade TD04HL16T internal Wastgate and Vacuum Actuator
And The Ecu has Been Chipped
Frank606
Hi
Fishman
01-10-2018, 03:35 PM #4
Since it is vacuum operated, you can't use a boost controller. Maybe if you connect it the 'wrong' way??
Fishman
