STD Tuning Engine Noise dissapears above 2000rpm
addi.bigg
OM605; 7,5mm elements
94
02-07-2018, 12:38 PM #1
OM605 7,5mm Dieselmeken elements, mechanical pump. Timing is in place, adjusted to the stock value.
The symptom is that while running in low rpm (1200-1300rpm), pressing the throttle pedal to speed up, some strange noise comes, some knocking which sudennly dissapears at 2000rpm. It seems like something is a bit late while increase the rpm and it's gain on at 2000rpm. Nothing above it. It always dissapears in the same rpm.
Any ideas what that can be?
addi.bigg
CutWeldDrive
02-08-2018, 11:50 AM #2
as far as i know the 7,5mm Dieselmeken elements have a different timing value to stock.
someone maybe able to confirm or tell me i'm talking crap.
but nearly sure i saw this somewhere
CutWeldDrive
Mr.Emo
Nissan Patrol -> 606 conversion.
69
02-08-2018, 12:18 PM #3
Yeah, they usually send out instructions with the pump.
Mr.Emo
addi.bigg
94
02-09-2018, 01:03 AM #4
(02-08-2018, 11:50 AM)CutWeldDrive as far as i know the 7,5mm Dieselmeken elements have a different timing value to stock.
The quantity is low 85-90ccm. I'm really not on the borderline from the upper side.
addi.bigg
addi.bigg
94
02-09-2018, 01:04 AM #5
If the oil pump chain is not tight enough what kind of noise it can make?
addi.bigg
02-09-2018, 04:56 AM #6
Mos probably the noise u mention is nailing due to excess advance in low rpm.
Once the threshold is passed it goes. Replace timming sprocket by a 605 N/A.
addi.bigg
94
02-12-2018, 03:07 PM #7
(02-09-2018, 04:56 AM)barrote Mos probably the noise u mention is nailing due to excess advance in low rpm.
I've sent you a pm.
addi.bigg
I've sent you a pm.
addi.bigg
94
02-13-2018, 12:42 PM #8
https://www.youtube.com/watch?v=NuL12eCn...e=youtu.be
Any suggestions regarding this noise?
This is the one that dissapears. If the engine is cold it is louder.
This post was last modified: 02-13-2018, 12:45 PM by addi.bigg.
addi.bigg
addi.bigg
94
02-13-2018, 12:44 PM #9
(02-13-2018, 12:42 PM)addi.bigg https://www.youtube.com/watch?v=NuL12eCn...e=youtu.be
In this you can hear when the noise dissapears.
https://youtu.be/GK_naRLhslk
addi.bigg
NoFear
08-07-2019, 12:43 AM #10
Same problem. What is the solution?
NoFear
08-08-2019, 09:25 AM #11
Those engines in the videos sound really bad... my sugestion on the advance mechanism is still valid.
Check out it is working properlly. Sometimes they do not, cause of a design flaw. Using a older 605 N/A solve the problem.
But its definetly timing related... its god damm advanced...
NoFear
08-14-2019, 01:45 PM #12
Is this normal sound? https://youtu.be/jl55lNaYGz0
https://youtu.be/HTKOZvW_tik
NoFear
