Unidentified Garrett turbo
Any ideas on what this is? Only marking is M24 on compressor housing. Appears to have a T6 flange, fitted to a 12litre Rolls Royce C series.
HX50 is from roughly 11 litre, and I think T6 flange? So maybe would spool eventually?!
Need to know the housing size to answer the spool question. And measure the wheels. If the number of blades does not permit a diameter measurement then you can measure a triangle from any three tips and compute the diameter of the circle which includes the three points.
