STD Maintenance General Cruise Control for W123 Manual
Biocruzer
01-03-2019, 05:32 PM #1
Hi, all!  Happy 2019!
Dunno whether the question is in the right forum or not: Does anyone out there know of a retro-fitted cruise control for a manual W123 converted from an auto? I still have the vacuum-operated CC 'switch' on the steering column, but would prefer something electronic.  Arduino, perhaps?
Cheers
Biocruzer
Cheers
baldur
Fast
509
01-03-2019, 09:08 PM #2
I don't know what engine you are running, likely OM617, but on the EDC engines (OM605/OM606) I have cruise control built in to my DSL1 ECU, all that is needed to make it work is a couple of resistors and a pair of switches.
Baldur Gislason
baldur
Baldur Gislason
frans-c
01-07-2019, 06:07 AM #3
The Rostra 250-1223 is all you'll ever need. I actually installed one on my old W123 280E and used the stock cruise stalk. A bit pricey, but really worth having a look at.
frans-c
Biocruzer
01-08-2019, 04:06 PM #4
(01-07-2019, 06:07 AM)frans-c The Rostra 250-1223 is all you'll ever need. I actually installed one on my old W123 280E and used the stock cruise stalk. A bit pricey, but really worth having a look at.
Thanks, Guys.  Mine is a 617 engine.  I've looked at the Rostra website, no info on Benzes, but I'll keep looking.
Cheers
Biocruzer
Cheers
frans-c
01-08-2019, 04:17 PM #5
The Rostra is universal - just hook the actuator cable to the throttle linkage and the electrical connections. You can use the Mercedes-Benz cruise stalk with a few modifications - there's a specific forum thread elsewhere (just Google it).
frans-c
NZScott
HX30W 73/44mm
398
01-09-2019, 12:35 AM #6
http://www.peachparts.com/Wikka/CruiseControlRostra
I was going to install one of these in my car because I was doing 8.5hr road trips for the last few months but have moved back home so probably won't bother any more.
I was wondering if the speed sensor could work off the crank, that way the engine might be useful for driving something when in neutral
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
frans-c
01-09-2019, 02:05 AM #7
Yup, that's the thread I was referring to.
frans-c
