STD Tuning Drivetrain W123 4spd swap driveshaft question
Dinman
08-06-2019, 07:36 PM #1
As title states:
As countless people have done/talked about doing, i'm putting an aluminum 4spd (83 240d) into my 1983 300D (us spec)
Bought the entire car for the swap. Wrecked in the front.
Here's my question- regarding the driveshaft.
From my understanding, ~19.5" is the length you want out of the front shaft in order to swap the 4spd into an om617 equipped w123. & a 240d 4spd shaft is 24". So lop ~4" off and balance?
Or- i found this shaft pictured. Coming from trans back, colors are Green/Green/Red/Green.
Seller claims "Mounting flange to end of coupling nut is 21"
It came from a 1982ish 300CD coupe, that had an iron box 4spd swap.
Shouldn't this shaft bolt right into my w123 300D sedan with the aluminum 4spd swapped in?
Thanks!
[Image: 48476517626_facce66d36_b.jpg]PHOTO_20190806_152448 by Daniel Inman, on Flickr
This post was last modified: 08-06-2019, 07:44 PM by Dinman.
Dinman
As title states:
Thanks!
NZScott
HX30W 73/44mm
398
08-08-2019, 01:31 AM #2
Remember coupes have a shorter body...I'd think they'd make the front shaft shorter rather than have a different rear one. Don't know if the 4 speed Getrag boxes are the same length as the iron ones. I can't tell you much else sorry...
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
Dinman
08-19-2019, 07:07 PM #3
(08-08-2019, 01:31 AM)NZScott Remember coupes have a shorter body...I'd think they'd make the front shaft shorter rather than have a different rear one. Don't know if the 4 speed Getrag boxes are the same length as the iron ones. I can't tell you much else sorry...
No worries, thanks for the reply. If anyone knows, im all ears. Trying to piece together everything for the swap
'83 240D 4spd
'83 240D slushbox
'83 300D + mud tires
'83 300SD
'89 300SEL
'00 Crown Victoria CNG
'10 E63
Dinman
'83 240D 4spd
'83 240D slushbox
'83 300SD
'89 300SEL
'10 E63
