STD Tuning Engine Is a HE351Ve too big for OM617???
Actros617
What's a spark plug???
49
03-01-2010, 04:33 PM #1
Just wanting to know is a HE351Ve too big for a OM617?? What kind of boost can i get out of them. I am not trying to get 500 hp here but, just a good turbo upgrade instead.
This post was last modified: 03-01-2010, 04:33 PM by Actros617.
1984 300SD 4 Dr Diesel Sports Car (ARGUS) (Mine)
1987 300SDL Cruiser STOCK (My fathers)
Actros617
03-01-2010, 05:07 PM #2
Thats the general concensus but nobody has tried. Physically its HUGE.
03-01-2010, 05:16 PM #3
Yes, its a very large turbo both in airflow and weight. Its the same as an HX40 (60x86mm compressor) and it weighs 50lbs.
Generally, all Holset turbos can "only" do 30-35psi, its the airflow capability that differs. If you need more pressure than that, you need compounds and/or porting.
This post was last modified: 03-01-2010, 05:21 PM by ForcedInduction.
Actros617
49
03-01-2010, 11:45 PM #4
How about a HE431Ve???
This post was last modified: 03-01-2010, 11:46 PM by Actros617.
Actros617
03-02-2010, 12:31 AM #5
Thats basically an HX50 and its used on 10.0L engines. Nothing under 5.0L would be able to flow enough air to use it, even an extremo-modded OM606.
Don't even bother asking about the HE551Ve or HE561Ve turbos, you'd need to split it across two engines to handle that much flow.
[Image: attachment.php?aid=593]
This post was last modified: 03-02-2010, 12:37 AM by ForcedInduction.
