advice please.
advice please.
Front and rear springs can be used as long as they are not SLS, also the front sway bar can be used if you trim it and use the 400E's brackets & bolts. Apart from hub's and brakes I can't think of anything else ( not really suspension ). Not sure on control arms.
Junkyards
Springs $50 each
Sway Bar $75-$125 /w Brackets ( should buy new bushings )
