STD Tuning Engine 5 cylinder M Super pump testing, fitted with M75 Floyd 7.5mm elements
  • 2 Vote(s) - 5 Average
Pages (4): 1 2 3 4 Next
DervTuning
05-12-2010, 10:20 AM #1
The super pump lives! For further testing of the bench settings on the pump, it is highly desirable to fit the pump to an engine to get dynamic qualitative, and quantitative feedback. The goal is to have a perfectly setup pump, with optimal delivery and response characteristics. This ensures that once the customer gets the pump, it is simply a plug and play situation. All fun, and no problems!
Therefore, I installed the super pump onto the engine in the 85 w123 that is running an authentic Garrett, basically full T4 turbo (compressor and turbine wheels, with a t3 inlet on the turbine housing), a 3" diameter downpipe, and water injection, for an evaluation of idle response, as well as other key parameters for performance. This is in the case that something needs attention, the pump can be fitted back to the bench for adjustments before being shipped out.
The results are in; the engine has never idled so well! Totally smooth, and driving at low speeds, the tip in response was excellent, with no issues with surging or other strange effects. Immediately, the effect of more fuel delivery, as well as faster delivery was observed, whilst driving a usual route.
Subsequently, merging onto the freeway, a wholly different beast was unleashed under the hood, with power like never before. Before I knew it, I was just over the speed I normally would drive at, just an ultra smooth flow of power coupled with fine sounds as the turbo responded. Very, very impressive! After a quick systems check, and a clear space in front of me, the transmission was placed into 3rd @ 65mph, yielding near 4K rpms and the throttle depressed; instantly, the boost shot up to ~30psi, as well as the EGTs which stabilized as the boost kicked in, and then wheelspin occurred! Incredible! This is not a small turbo either, but I've never seen it respond so well compared to other platforms I've tried the same turbo in (gas engines).
It should be noted that prior to the super pump install, with the stock MW adjusted to it's maximum, I was getting ~10 psi max.
I will be able to resume testing later in the day, and if everything goes as well as it has, the super pump will be shipped out straightaway!
DervTuning
GREASY_BEAST
05-12-2010, 10:53 AM #2
EXCELLENT news DervTuning!!!
GREASY_BEAST
Jtn190D
MERCEDES DIESEL POWER!
192
05-12-2010, 11:18 AM #3
Awesome!!!! Can't wait to get one.
Jtn190D
Rudolf_Diesel
Ask me if I care...
05-12-2010, 11:32 AM #4
Big GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig Grin
It's all mine!!!!!
Rudolf_Diesel
It's all mine!!!!!
05-12-2010, 11:56 AM #5
We want 0-60 times! This thread is worthless without a video! Its like reading text porn Big Grin
DervTuning
05-12-2010, 12:01 PM #6
I will get some photos, and a video or two Big Grin
(05-12-2010, 11:56 AM)winmutt We want 0-60 times! This thread is worthless without a video! Its like reading text porn Big Grin
DervTuning
George3soccer
05-12-2010, 02:39 PM #7
Awsome Dervtuning, can not wait for this.
George3soccer
yankneck696
395
05-12-2010, 02:56 PM #8
Stiffy !!!!!!!!
yankneck696
Stiffy !!!!!!!!
mbenzo300td
05-12-2010, 04:11 PM #9
DervTuning. Is this something you done yourself? If so are you also Tuning om603 pumps as well? This sounds amazing, keep us posted.
mbenzo300td
05-12-2010, 06:05 PM #10
Congratulations DervTuning, tomnik and Rudolf_Diesel, truly awesome! Can't wait to see this thing in action! Cool
Biohazard
Smokin like a champ!
376
05-12-2010, 07:36 PM #11
THIS is the news I've been anxious to hear! I'm grinnin ear to ear reading this thread! Big Grin
Biohazard
jonbobshinigin
05-13-2010, 07:20 AM #12
Ok ok...Let's move on to the MW/OM603 pump now can we???? Haha, thanks, great work!
1987 300TDT - 260,000 Miles
jonbobshinigin
DervTuning
05-13-2010, 09:59 AM #13
The sound worked fine on all my computers, but when uploaded to youtube, it garbled the audio Angry. It is too bad, as the engine sounds so mean now Big Grin I will try to fix it somehow tonight.
Also, I found out after I did the videos that the water injection nozzle was 100% clogged. So, I made my own nozzle, that flows about 2 to 3 times as much per given unit of time, yet atomizes better than before. The car is even faster now as a result! I am going to take more videos when the roads dry up; lots of strong thunderstorms about the area...
Here you go:
0-60 run
Free Revving
Idle and rev
Smooth idle
We can do all types of pumps used on just about any Mercedes, including the electronic pumps found on the w210 chassis with the OM606 engines.
Thanks for the compliments Cool A lot of hard work went into this project, and look for more fun once the pump gets shipped off Big Grin
DervTuning
Here you go:
0-60 run
Free Revving
Idle and rev
Smooth idle
Biohazard
376
05-13-2010, 10:35 AM #14
Watchguard Proxy at work = no video watching till I get home. Angry This day had better go by fast! I'm now anxiously awaiting my pump! New turbo is on... need more fuel... Big Grin
Biohazard
tantank79
T3-45
109
05-13-2010, 11:32 AM #15
If I'm seeing the video correctly, that looks like 0-60 in 8 seconds.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
300SD81
05-13-2010, 12:55 PM #16
(05-13-2010, 10:35 AM)Biohazard Watchguard Proxy at work = no video watching till I get home. Angry This day had better go by fast! I'm now anxiously awaiting my pump! New turbo is on... need more fuel... Big Grin
proxy.org Wink
I had one set up on my own secure server back when I was in highschool.
Videos look sweet!
Ich liebe meine Autos!
300SD81
proxy.org Wink
Videos look sweet!
Alastair E
Moderator?--Nah...
266
05-13-2010, 01:40 PM #17
(05-12-2010, 04:11 PM)mbenzo300td DervTuning. Is this something you done yourself? If so are you also Tuning om603 pumps as well? This sounds amazing, keep us posted.
OM.602 and OM.603 have a similar pump, Namely,an 'M' (PES.5 or 6 M. RS320.xxx) type Bosch pump as opposed to the OM.617 that 'generally' in USA market has the 'MW' (PES.5.MW.R?) type pump
Euro OM.617.912 has 'Generally' an 'M' type.
What has been done here is a 'Euro M' type has been modded using Tomnik's M75 (7.5mm) Floyd Elements, (Originals are 5.5mm) and set up to run correctly on a proper Test-Bench-
-This is summit that can Only be done by someone who knows what they are doing using the developed by Tomnik and I believe 'DervTuning' Test-Plan and has a Test-Bench for driving the pump and setting up the Governor and the elements.
But to answer your original question, the same type elements can be fitted to your original OM.603 'M' type injection-pump, but you would Have to send the pump to the guy who did this one and specify exactly what you're looking for performance wise and what other mods you expect to do either down the road or at the same time as the pump mod.....
Alastair E
Biohazard
376
05-13-2010, 01:51 PM #18
Request denied by WatchGuard HTTP proxy.
Reason: one or more categories denied helper='WebBlocker.Standard' details='local-exception'
Method: GET
Host: www.proxy.org
Path: /
proxy.org
Sonofa... turns out the proxy is proxy blocked. AngryAngryAngry Hahaha Rolleyes
I'll be checking out those video's just as soon as I get home! Today is going pretty quickly so far. Smile
Biohazard
Method: GET
Host: www.proxy.org
Path: /
proxy.org
05-13-2010, 03:42 PM #19
(05-13-2010, 11:32 AM)tantank79 If I'm seeing the video correctly, that looks like 0-60 in 8 seconds.
Even with a ~1sec flare in third! Bad ass.
Biohazard
376
05-13-2010, 10:03 PM #20
I can finally see the video!! That is amazing! Thats too bad the audio didn't work out, hope you can get that figured out. I can hardly wait to get my pump too! I love that you had to lift at 45 due to wheel spin... Cool Keep up the great work, DervTuning & Tomnik! Well, Rudolf, looks like you have some fun work ahead of you! Smile We're all looking forward to your updates as well.
Biohazard
mbenzo300td
05-13-2010, 11:21 PM #21
(But to answer your original question, the same type elements can be fitted to your original OM.603 'M' type injection-pump, but you would Have to send the pump to the guy who did this one and specify exactly what you're looking for performance wise and what other mods you expect to do either down the road or at the same time as the pump mod.....)
Sweet. Where do i send it and how much will it cost?
This post was last modified: 05-13-2010, 11:23 PM by mbenzo300td.
mbenzo300td
George3soccer
05-13-2010, 11:42 PM #22
Got to wait in line my friend.
George3soccer
jonbobshinigin
05-14-2010, 12:32 AM #23
It looked more like 7 seconds to me...Also, this is being done here in the US right? I thought that was the original idea with Derv and Tom, but then I read something that indicated otherwise.
jonbobshinigin
Rudolf_Diesel
Ask me if I care...
05-14-2010, 05:11 AM #24
(05-14-2010, 12:32 AM)jonbobshinigin It looked more like 7 seconds to me...Also, this is being done here in the US right? I thought that was the original idea with Derv and Tom, but then I read something that indicated otherwise.
This is a joint effort between Tom and DervTuning...I just happen to the first in line with the M-pump. The elements are from Tom and he is in Germany - DervTuning is in Maryland.
As soon as I get the car up and running, which could be a few weeks due to the extensive list of things to do ,I will definitely post some videos of the same.
Rudolf_Diesel
05-14-2010, 05:48 AM #25
What cost are we looking at?
Rudolf_Diesel
Ask me if I care...
05-14-2010, 05:56 AM #26
(05-14-2010, 05:48 AM)ForcedInduction What cost are we looking at?
You will have to talk to Dervtuning to find that out - I am verboten from discussing the details...
Rudolf_Diesel
tomnik
05-14-2010, 03:59 PM #27
Peanuts, regarding what will turn out if the small rest of the job will do well.Big Grin
Jokin', 60 Eur/element from my side.
Contact Derv for the swap and set up.
and even mini peanuts compared to the beautiful engine of Rudolf.
Tom
tomnik
Tom
05-14-2010, 07:27 PM #28
could a om616 pump be tuned up?
jonbobshinigin
05-14-2010, 10:08 PM #29
Tom, any discount for quantity, pre-pay, or combined shipping?
jonbobshinigin
tomnik
05-15-2010, 12:30 AM #30
(05-14-2010, 10:08 PM)jonbobshinigin Tom, any discount for quantity, pre-pay, or combined shipping?
60 EUR is the pick up price.
Quantity: custom declaration!
Pre-pay: anyway
shipping: to be paid by the one who orders
To be honest, I am private not a shop, the elements came out of the hobby.
But to get anything at all I had to order more elements that I could ever use. This is the only reason why I am willing to sell them, not to make profit more to get back my money. Next, check the quality of these elements and tell me what you want to pay.
Tom
tomnik
Pre-pay: anyway
Tom
Biohazard
376
05-15-2010, 01:15 PM #31
(05-14-2010, 07:27 PM)willbhere4u could a om616 pump be tuned up?
Personaly, I would love to see someone do this! Especially with the older turbo kit, or a modern version of it. I've got a spare 616 engine sitting in my project car. It's currently just being ballast until the 617 goes in. Big Grin My Dad, my brother, and I have kicked around the idea of swapping the 616 into an older mini-truck or even an old hotrod for bombing around in, but the list of current projects places that squarely into next decade. Although... now you got me thinking of swapping the 616 into my track roadster project... it would be lighter than the currently planned 617... Dodgy Heh, too many projects in front of that one for now. Need to crank up the pump in the Pumpkin and re-dyno with the bigger turbo, need to build a bigger exhaust for it, elec radiator fans, and then it's ready for the MW pump with 6.5 elements. Big Grin I'm waiting at top speed for that one. Well, I'm off to the man-cave to work on the Pumpkin. Need to get it ready for more fuel.
Biohazard
Alastair E
Moderator?--Nah...
266
05-15-2010, 04:37 PM #32
(05-15-2010, 01:15 PM)Biohazard
Does your 616 have the 'M' type or the MW type....?
IF M then yes, you go 7.5 Floyd, if MW then 6.5 is your way forward.
Doesnt Matter What the Pump is OFF, just matters What Type, (M or MW) It actually IS!
(I got 616 M type in the corner of kitchen floor at the mo!)
[Image: 300TDnoplate.jpg]
Alastair E
05-15-2010, 05:22 PM #33
(05-15-2010, 04:37 PM)Alastair E
What is the proper way to go about finding out if its an M or MW pump that is on the car?
E300TSC
Turbo-Supercharged
321
05-15-2010, 08:32 PM #34
Look at the delivery valve holders. Splined shafts are M, flanges with 2 bolts are MW.
E300TSC
05-15-2010, 09:24 PM #35
(05-15-2010, 08:32 PM)E300TSC Look at the delivery valve holders. Splined shafts are M, flanges with 2 bolts are MW.
This would be the same way to look for the 5cyl pump as well?
05-15-2010, 10:34 PM #36
That's good info so theoretically the M with 7.5 is capable of more power but the MW with 6.5 should still make good power
I've got all of the parts in my garage to build an om616 I was planing on rebuilding my spare 616 with new liners and rings and bearings with the om617 turbo rods/pistons If I can find a shop to mod the block for the squirters then port the head a little fresh valve job and seals mabey a cam grind and pump!
Biohazard
376
05-16-2010, 02:04 AM #37
Do it! I've got a spare head that's ported (617 head). Thats waiting it's turn for install on my engine, along with slightly lowering compression to about 18:1. I had a cam reground also, that goes in with the head install. All in good time...
A buddy I was deployed with in Bosnia took both the heads off his 6.2L chevy utility truck and ported them in the tent at night, using the power from the generator. I don't remember if he messed with the pump or not, but holy crap that damn truck had some scoot to it! It lasted about 3 months and then he blew the engine. I'm pretty sure he was messing with the pump at that point, but he was on a different base by then also so I wasn't able to witness like the porting!
It's amazing how much difference a little gasket matching can do for waking up an engine. Smile
Edit: My 616 has the MW pump on it.
This post was last modified: 05-16-2010, 02:08 AM by Biohazard.
Biohazard
Rudolf_Diesel
Ask me if I care...
05-19-2010, 07:50 AM #38
Here are a couple of more videos - sound is good, but pic qaulity is not, enjoy.
http://www.youtube.com/watch?v=tvmO58hswFk
http://www.youtube.com/watch?v=vPuBVwaFgDo
http://www.youtube.com/watch?v=eil0OBxlf-A
This post was last modified: 05-19-2010, 07:52 AM by Rudolf_Diesel.
Rudolf_Diesel
05-19-2010, 08:48 AM #39
* winmutt waits patiently for the bottom to fall out of the euro...
Rudolf_Diesel
Ask me if I care...
05-19-2010, 09:12 AM #40
(05-19-2010, 08:48 AM)winmutt * winmutt waits patiently for the bottom to fall out of the euro...
I know what you mean buddy!
Fortunately the next phase of the project is all available in the USA...
A Tremec TKO 500 5-speed transmission...more deatils and a seperate thread to follow.
This post was last modified: 05-19-2010, 09:13 AM by Rudolf_Diesel.
Rudolf_Diesel
DervTuning
05-19-2010, 09:50 AM #41
Get the 600, it is only about $100 more, and you might need it...
0-60 with water injection on
FMIC install soon...
The pump used on the om616 should be no problem to fit larger elements. In addition, any of the electronic pumps used on the 606 or 605 (etc) can be fitted with larger elements, and tuned as well.
Considering the massive power increase from a pump swap, and a turbo, the dollars to performance ratio is excellent. Indeed, Tom has it right, it costs peanuts, all things considered Cool
(05-19-2010, 09:12 AM)Rudolf_Diesel
DervTuning
meareweird
05-19-2010, 02:08 PM #42
how much for an mpump for 602 engine?
meareweird
Alastair E
Moderator?--Nah...
266
05-19-2010, 02:49 PM #43
(05-19-2010, 02:08 PM)meareweird how much for an mpump for 602 engine?
Assuming Turbo 602 engine...?
Parts from Tomnik in Germany are 60 eur each, shipping/customs etc extra,--You'll need 5.
Contact Derv Tuning direct for fitting to Your pump and setting up. Not possible to swap these parts yourself....
Alastair E
shredator
ridiculous snail orgy of power
56
05-19-2010, 08:44 PM #44
What is the timing set at? Stock injectors?
looks like fun...
shredator
looks like fun...
DervTuning
05-20-2010, 10:39 AM #45
The timing is set at 25 degrees, and the injectors are the stock, original bits.
It is a whole different car now Big Grin Even driving to get groceries is totally civil, with zero drawbacks.
I shall soon be able to report the fuel usage, but thus far, the fuel lamp has not illuminated with about 500 miles driven (about 40 miles of that was with the MW, plus lots of (collected in a pan) leaking when swapping the MW to M pumps Undecided). I continue to be impressed!
(05-19-2010, 08:44 PM)shredator What is the timing set at? Stock injectors?
looks like fun...
DervTuning
looks like fun...
jeemu
&quot;some people do, some people talk.&quot;
457
05-20-2010, 03:41 PM #46
How much engine revs and what rpm pump stop increacing fuel?
jeemu
DervTuning
05-24-2010, 10:50 AM #47
Very good question. I will try to find out what it is, dynamically, while the pump is on the car.
Thus far from the videos, it looks like I have not taken it much past 5K rpms. The stock cam seems allow for the rpms with the power increasing all the way to the shift point. I have not felt the power drop off at all.
It is hard to follow since everything occurs so quickly now. The latest video revealed to me the rpms, as I am usually trying to monitor the EGT's as well as the road!
I also filled up the tank as the low fuel indicator lamp just started to illuminate on and off. At 545 miles, I filled the tank to ~18 gallons (it was something like 17.95 gallons). Not bad, especially since this was a test tank that I pushed the car on just about every occasion I was able to, and included the requisite grocery getting as well as commuting.
(05-20-2010, 03:41 PM)jeemu How much engine revs and what rpm pump stop increacing fuel?
DervTuning
05-24-2010, 03:25 PM #48
(05-24-2010, 10:50 AM)DervTuning I also filled up the tank as the low fuel indicator lamp just started to illuminate on and off. At 545 miles, I filled the tank to ~18 gallons (it was something like 17.95 gallons). Not bad, especially since this was a test tank that I pushed the car on just about every occasion I was able to, and included the requisite grocery getting as well as commuting.
Are you going to be able to but another tank through? I'd love to hear that number stay true, helps justify the $ to my accountant (wife).
jonbobshinigin
06-01-2010, 09:31 PM #49
I know I have seen this addressed briefly before but: What would something like this look like on a NA (Naturally Aspirated) 617?
jonbobshinigin
tomnik
06-02-2010, 12:01 AM #50
to be honest, not too exciting up to now.
I made an IP and my friend is running it in his n/a.
First thing was that the car smoked a lot and was nailing (in combination with power loss) beyond let's say 3500-4000 rpm and pedal depressed. Then we decreased the full load and everything was perfect. No power gain at low rpm but beyond 3000 the engine climbed up to 5400 like hell. He has the 3.8?? rear end and top speed is limited by rpm max.
Now this lazy bone is not able for weeks now to play with timing. Actually the timing is set at 8 deg before TDC! This was how it came up when he installed the IP. In my opinion this is far too late but he can't find the time to change it.
Also those are the rest of the 7mm crap elements I had sitting around where we took the 5 best for the IP.
I will up date the progress as soon as he gets further.
Tom
(06-01-2010, 09:31 PM)jonbobshinigin I know I have seen this addressed briefly before but: What would something like this look like on a NA (Naturally Aspirated) 617?
tomnik
Tom
