STD Tuning Engine leaky oil pressure gauge
  • 2 Vote(s) - 2.5 Average
rdirtycar
flash gordon
145
06-26-2010, 09:13 AM #1
oil gauge leak behind the dash. Anybody have luck fitting an electric pressure sender where the oil pressure sender line comes out of the engine? Anyone know the pipe fitting size? Maybe there's a better location to tap into? I'd like to use VDO but there may be a higher quality option for an electric sender hanging off the bottom of a diesel engine. thanks....
Maybe better to run a copper or brass line up higher on the engine and bracket a little drop ear type elbow fitting to the block.
This post was last modified: 06-26-2010, 09:20 AM by rdirtycar.
rdirtycar
Einar
06-26-2010, 10:31 AM #2
What about pulling a gauge and sender from a 201 or 124?
Einar
06-26-2010, 10:45 AM #3
Why not replace the gauge or fix it? Cracked gauges usually just need to be resoldered at the base of the bourdon tube.
This post was last modified: 06-26-2010, 10:46 AM by ForcedInduction.
rdirtycar
flash gordon
145
06-26-2010, 12:54 PM #4
later models are compatible? A jewler would make quick work of that little tube without running the good solder joints and filling the thing up and ruining it.
rdirtycar
charmalu
06-26-2010, 03:38 PM #5
Why reinvent the wheel trying to cobble something in there?
there are plenty of them in the JY, just pull one for about $7.
If you want a really nice pretty one, $300.Big Grin
Charlie
charmalu
Charlie
rdirtycar
flash gordon
145
06-26-2010, 07:07 PM #6
I would love to throw a piece of painted aluminum in there that holds the original speedo tach/clock and room for three or so aftermarket guages.........100 psi oil pressure, oil temperature, water temperature, fuel level.... I wish there was a guage cluster conversion kit for this car because like charmalu said the new guage cluster is many hundreds. love to have an extra cluster to mess with so I can know my readings in the meantime.
I'm going to post a WTB for a worn out cluster now. anyone here have one I could send you a money order for? I could come up with something pretty cool in a few evenings work.
This post was last modified: 06-26-2010, 07:09 PM by rdirtycar.
rdirtycar
06-26-2010, 07:14 PM #7
I have a spare but it reads in *F and psi instead of *C and bar. Functionally identical.
This post was last modified: 06-26-2010, 07:15 PM by ForcedInduction.
Syncro_G
0-60 in 29 sec
280
06-27-2010, 01:40 PM #8
if you insist on going the electric sender route,
I recommend getting a relocation kit. you can find them for VW's and other makes. you'll get 12 or so inches of braided hose to go from the oil filter housing to the firewall. and then get a VDO sender that matches the range of the gauge you install.
if it were my car, I'd just fix the system that's there - it's easy to replace the hose and as the other guys suggest, it might be easy to fix the gauge too. and you end up with a nice, OEM looking setup.
The G-wagen has an electric gauge so I had to do the relocation kit when I installed the 617A
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
rdirtycar
flash gordon
145
06-28-2010, 11:31 AM #9
here's the plan..... oil pressure gauge will go in the overhead console that's coming in the mail with a relocation kit. Oil pressure will read 0 in the stock location but at least i'll have a stock instrument panel to look at. A modern gauge will tell me the real oil pressure, and the old gauge will just be disconnected and the oil behind the dash cleaned up as best as possible. Thanks for the help guys..
rdirtycar
rdirtycar
flash gordon
145
06-28-2010, 03:06 PM #10
is this the sender relocation kit?
http://store.42draftdesigns.com/VW-Oil-P...p_314.html
rdirtycar
rdirtycar
flash gordon
145
07-13-2010, 03:02 PM #11
Does anyone know the thread pitch and size of the threaded hole coming out of the oil filter housing used for the oil pressure sender tube? Is it M10x1 like any VDO sender?
rdirtycar
07-13-2010, 05:52 PM #12
I want 42's oil catch! http://www.42draftdesigns.com/categories...hcans.html
rdirtycar
flash gordon
145
07-13-2010, 05:59 PM #13
(07-13-2010, 05:52 PM)Captain America I want 42's oil catch! http://www.42draftdesigns.com/categories...hcans.html
buy me that
I heard the MANN pro-vent 200 works too
rdirtycar
buy me that
rdirtycar
flash gordon
145
07-13-2010, 07:18 PM #14
hope you don't mind Captian I reposted your link on this thread:
http://www.superturbodiesel.com/std/home...-t-12.html
some good thread
rdirtycar
some good thread
07-13-2010, 11:13 PM #15
(07-13-2010, 05:59 PM)rdirtycar
buy me that
Lol, easy there caveman! Your pic looks like one too haahhaha
(07-13-2010, 07:18 PM)rdirtycar hope you don't mind Captian I reposted your link on this thread:
some good thread
Hey yeah no Prob! I'm gonna go read that beehotch right meow!
Dirty, I added another link I just found a couple days ago to the oil separator thread.
This post was last modified: 07-13-2010, 11:52 PM by Captain America.
buy me that
some good thread
07-14-2010, 04:15 PM #16
Did you just say meow? What do I look like a cat jumping all mimby bimbly like from tree to tree drinking milk from a saucer?
rdirtycar
flash gordon
145
07-15-2010, 06:53 AM #17
(07-13-2010, 11:13 PM)Captain America
buy me that
some good thread
Someone said my avatar is from "Running Man". It's sooooo nice to see tuning companies specializing in 617 parts. It probably took me more than an hour to grind and drill out a block off plate for my EGR in my wood shop, and it still looks like it was made in a wood shop.
rdirtycar
buy me that
some good thread
07-15-2010, 08:30 AM #18
How can somebody confuse movies like Flash Gordon and Running Man?
This post was last modified: 07-15-2010, 08:30 AM by ForcedInduction.
07-15-2010, 10:07 AM #19
Yeah meow throws people for a loop everytime haha
07-16-2010, 10:07 AM #20
One good thing about using the electronic sender setup is an idiot light. I wouldnt mind someone getting this working. I think there was a thread on peach part a while ago.
07-16-2010, 10:23 AM #21
An electric sender is a variable resistor. You'd need a separate pressure switch to trip a light.
07-16-2010, 10:41 AM #22
Yeah there was a thread... Basically it used the sender from a older chev SBC
rdirtycar
flash gordon
145
07-16-2010, 11:30 AM #23
On my Vanagon I had a VDO oil pressure sender with two posts, one for the gauge, the other for a warning light AND a buzzer. According to me, it's not an idiot light if there's a gauge too, it's a warning light. The buzzer can get annoying under certain circumstances, like under hood maintenance.
rdirtycar
07-16-2010, 02:36 PM #24
(07-16-2010, 11:30 AM)rdirtycar The buzzer can get annoying under certain circumstances, like under hood maintenance.
You should tap the alternator light system (field coil), that way the buzzer only operates if the engine is running.
This post was last modified: 07-16-2010, 02:36 PM by ForcedInduction.
rdirtycar
flash gordon
145
07-16-2010, 03:27 PM #25
(07-16-2010, 02:36 PM)ForcedInduction
That's a very good idea. I didn't know that I could do that. A low oil buzzer is a good idea because of all the exterior oil lines.
rdirtycar
07-16-2010, 04:10 PM #26
Yeah those lines are ridiculous in the fact that they seem to just fail and leave you with a smoked motor... I would rather just a red light that lights up on the dash myself, like a red LED. It wouldn't use any power, wouldn't buzz at you but be bright enough to notice if something fails
rdirtycar
flash gordon
145
07-17-2010, 09:24 AM #27
I had the horn wired to the oil pressure sender for about five minutes before I used a buzzer behind the dash. Figured it would warn me if the car was idling outside. A little more complicated circuitry would allow that. I leave the Benz idling outside for 10-15 minutes at a time. That'd be nice.
rdirtycar
85-300Dt
07-17-2010, 04:12 PM #28
oil pressure warning stuff
http://tinyurl.com/2agys27
http://tinyurl.com/22oa23n
http://tinyurl.com/33uj7qa
This post was last modified: 07-17-2010, 04:34 PM by 85-300Dt.
07-19-2010, 08:01 AM #29
Thanks!
Thanks!
rdirtycar
flash gordon
145
08-01-2010, 08:53 PM #30
Is there a simple way to attach an electric pressure sender to this engine? The outlet to the gauge is a strange untapered thread. Has anyone installed an electric oil pressure sender on a 617?
rdirtycar
08-05-2010, 10:05 AM #31
Definitely need pics of those parts and the new setup!
rdirtycar
flash gordon
145
08-06-2010, 09:12 PM #32
I sure will. It's been mostly cleaning and dismantling so far. I took a week off from work to get this done quickly. My tooth brush is on the sink outside the garage. I haven't shaved for the longest time in years. Expect a full report when I finally get to sit at the computer.
rdirtycar
08-06-2010, 10:32 PM #33
(08-06-2010, 09:12 PM)rdirtycar I sure will. It's been mostly cleaning and dismantling so far. I took a week off from work to get this done quickly. My tooth brush is on the sink outside the garage. I haven't shaved for the longest time in years. Expect a full report when I finally get to sit at the computer.
So basically you look like the guy in your picture? Tongue
This post was last modified: 08-06-2010, 10:33 PM by Captain America.
rdirtycar
flash gordon
145
08-08-2010, 07:44 AM #34
That's my dad.
rdirtycar
That's my dad.
08-08-2010, 06:46 PM #35
oh haha
oh haha
rdirtycar
flash gordon
145
08-17-2010, 04:22 PM #36
(08-05-2010, 07:41 AM)rdirtycar Stewart Warner part number 7011546 converts the oil filter housing to M-10. Then there is another adapter from M-10 to the NPT for 42draftdesign.com oil sender relocation kit hose to the kit's manifold that holds a 150psi sender with M-10 threads. That's how I'm doing it.
Electric oil pressure gauge where the sun visor was.
Before anyone goes and tries the Stewart Warner gauge adapter, let me try an idea I have with a 12x1.5mm banjo connection and some tubing running to a tee that for now can hold my sender and some day connect to a bypass oil filter. There is just no sealing surface on the little adapter. There is no shoulder for a crush washer and the threads are not tapered at all.
rdirtycar
08-17-2010, 05:16 PM #37
I wanna run a bypass filter too
rdirtycar
flash gordon
145
08-20-2010, 09:48 PM #38
12mm 1.5 banjo works great. I'm running AN fittings from the stock location. The worst part is going to be finding a place to mount gauges and keep a somewhat stock looking interior.
rdirtycar
08-20-2010, 10:01 PM #39
Pictures of everything!
