Seeking Manual Shutoff & Vacuum Cover
Hey Guys,
Someone I know in Iceland has an OM617 in a Unimog. While looking through his photos I found this:
http://www.pbase.com/jonash/image/22641788
He confirmed the cover was a MB part, but didn't have a part #. Waiting to see what model it came from. Some things get lost in translation I think.
Anyways, this means two things to me, I can simplify making a vacuum pump cover, and #2, most importantly, engines fitted with a vacuum pump cover wouldn't have vacuum (durrrr) so therefor no vacuum shutoff.
Anyone have any info on maybe a mechanical shutoff? Trying desperately to find out, as I will be retrofitting this to my truck.
THANKS!
You can hook up a cable to operate the shutoff, not sure about the plate, but I would just make one out of your metal of choice.
I would rig up a universal choke cable in place of the shut off solenoid!
If the engine came without a vacuum pump it should have a non-vacuum stop mechanism. Since the cover is an MB part then look through the world EPC and you should find what MB used for those engines.
However, I believe the engines the cover was made for are the old pneumatically governed injection pumps which means they already had the "gorilla knob" start/stop system.
There are also many compact electric vacuum pumps. Ford uses one in the Powerstroke models thats about the size of a fist. Part number 6C3Z2A451A.
