Oil temp sender question.
Yes, as long as it has a way to seal on the oil pan. An o-ring or crush washer.
However, it will be very low to the ground. Nearly every 616/617 I see in the junkyards has a side of the plug head scraped off. I wouldn't do it without getting the belly pan first.
Oil plug scrapped?? I dont see any scrapings on my drain bolt, the plug resides at the rear of the oil pan i dont see possible ways for it to scrape unless your trying to rally jump with your Mercedes
