STD Tuning Engine new injector lines
new injector lines
new injector lines
HughF_UK
09-10-2010, 04:53 AM #1
My 6 injector lines are all a bit burnt and rusty having been in the fire... where can I get new ones (apart from the main dealers)???
Also, does anyone know a part number for the plug that clips onto the glowplugs, if not, I'll thread them m4 and bolt on some ring terminals.
Cheers,
Hugh
HughF_UK
Cheers,
Hugh
E300TSC
Turbo-Supercharged
321
09-10-2010, 05:07 AM #2
Why not sand/sandblast and paint the injection lines? Over here, the lines are $50 each at the cheapest. You can also try bending your own which is much cheaper but of course, much more challenging.
As for the GP terminals:
The plastic housing: A 019 545 54 28
The metal contact: A 003 545 26 26
Most MB connectors are completely servicable and "unsnap", allowing you to repair or replace only the part that's damaged.
This post was last modified: 09-10-2010, 05:09 AM by E300TSC.
E300TSC
HughF_UK
09-10-2010, 05:38 AM #3
Given that I have some very good contacts in a surface coatings/blasting/powder coating company, that would be the most sensible course of action, thanks!
I'll price up the 12 bits I need to make a glowplug harness
HughF_UK
HughF_UK
09-10-2010, 08:26 AM #4
£14 for all the bits, will be in tuesday Smile Cheers!
HughF_UK
