STD Tuning Engine W210 OM606 Fueling??? Experts needed!
gen3performance
I like the smell of No. 2......
89
09-15-2010, 11:54 PM #1
Ok...so a lot of you have probably seen my ad for my car I'm trying to sell. Well since nobody seems interested I might as well have some more fun with the car!
So my plan is to make this thing faster in some way shape or form.
So what are my options here??? I got a lot of questions!!!
Question 1: What is the maximum power that this stock OM606 pump will provide? I have seen the USA Speed Tuning products that will bump the power to roughly 215hp but how much more is available?
Question 2: Are there other companies offering tuning for this car/powertrain? Better options than Speed Tuning?
Question 3: Can I have larger elements installed and still retain my ecm controlled throttle?
Question 4: How soon before the trans scatters all over the road? I guess I would really like to know if these transmissions are strong or not really. I got 300,000+ miles and the fluid looks damn good for being an original trans...but will I destroy the trans with a chip?
I'm really looking to start with a chip, but would also like to know how far I can push the power and still retain driveability and reliability. Thanks for your input and expertise in advance!
If it dont smoke black, send it back! Sorry EPA
1981 300SD...Too much propane = bent rods. Junked
1980 240D...Body fell off. Saved drivetrain and junked
1985 300D...No.2 and N2O = 16.35@85mph. Sold Sad
1999 E300TD...3" exhaust with banks muffler, Hx-35, 215hp tune, IP resistor box, bad crankshaft snout Angry
2005 E320 CDI...AMG injectors, EGR removed, mapping
Vids! http://www.youtube.com/user/silverado408
Pics! http://s776.photobucket.com/albums/yy42/...rformance/
gen3performance
muuris
OM605
318
09-16-2010, 10:25 AM #2
1: About 250hp.
3: Yes.
4: 722.6 is pretty strong stock, but can be strengthened to withstand 300-400hp.
The biggest restriction is the small stock turbo.
muuris
1: About 250hp.
3: Yes.
gen3performance
89
09-16-2010, 01:35 PM #3
Thank you for the quick reply! 250hp was a little more than I expected! Corrtect me if I'm wrong, but I have heard these engines can handle 400hp in stock form. Maybe? Is there a common turbo that people swap out on these?
gen3performance
09-16-2010, 03:55 PM #4
250hp is what the pump can flow, but it can't flow that much safely due to the long injection duration. Thats why the tuners only bump it to 215hp.
gen3performance
89
09-16-2010, 04:54 PM #5
So at the 250hp mark it stresses the pump too much?
gen3performance
09-16-2010, 05:05 PM #6
No. The injection duration is too long. The fuel is injected too late into combustion and can't burn completely, it results in unsafe exhaust temperatures.
gen3performance
89
09-16-2010, 05:15 PM #7
Ah! I read ya! Just more of a reason for more air!
gen3performance
09-16-2010, 05:18 PM #8
More air doesn't change physics.
gen3performance
89
09-16-2010, 05:23 PM #9
I'll probably come up with something
gen3performance
09-16-2010, 05:50 PM #10
What ya need is an EGT gauge! And eventual a built pump!
gen3performance
89
09-16-2010, 06:16 PM #11
For sure! My plan at the moment is an A pillar guage pod with EGT's and boost.
gen3performance
09-18-2010, 02:13 PM #12
Can you advance IP timing a little to battle the long injection duration?
muuris
OM605
318
09-18-2010, 02:16 PM #13
(09-18-2010, 02:13 PM)Captain America Can you advance IP timing a little to battle the long injection duration?
It won't help, can't advance that much. More air doesn't help much either. Only cure is bigger elements.
muuris
09-18-2010, 02:18 PM #14
Sad Waaaaaaa!
Why can you not? because it cannot physically advance far enough or because the injection would just be too soon?
This post was last modified: 09-18-2010, 02:19 PM by Captain America.
Sad Waaaaaaa!
09-18-2010, 04:59 PM #15
Injection would be far too advanced. You'd end up partially compressing expanding gasses.
09-18-2010, 05:49 PM #16
(09-18-2010, 04:59 PM)ForcedInduction Injection would be far too advanced. You'd end up partially compressing expanding gasses.
crap, That's what I was afraid of...
gen3performance
89
09-18-2010, 06:07 PM #17
I'm thinkin I'm going to go with the max fuel tune and use water injection controlled by a boost switch. It should drop the egt's and make more power.
gen3performance
muuris
OM605
318
09-19-2010, 01:45 AM #18
(09-18-2010, 06:07 PM)gen3performance I'm thinkin I'm going to go with the max fuel tune and use water injection controlled by a boost switch. It should drop the egt's and make more power.
It won't help! If injection duration is too long, the last "drops" of fuel just produce heat and smoke instead of power. So you'll end up making heat and using water injection to cure it. You'll get better results using shorter injection duration and you don't have to use water injection.
I assume this tuning will be done in a dyno, so it should be easy to find the point where increasing injection duration won't show up in torque graphs but in smoking.
muuris
gen3performance
89
09-19-2010, 09:30 AM #19
I understand that the injection duration will be too long, but I really dont want to install larger elements in the pump unless I have to have the pump rebuilt.
Also I cant tune the car on a dyno since I don't know anyone in the area with the capabilities of modifying the ecu.
Basically I am looking at from the position that I would rather have 250hp than 215hp and if I have to inject water thats ok with me since water will cool the egt's and generally make some power. If it smokes, I'm ok with it since I like smoke and I can make people behind me mad Big Grin
gen3performance
muuris
OM605
318
09-19-2010, 10:40 AM #20
The point is: when you go beyond a certain point, you will not get any more power. Only smoke and heat. Water injection won't give any more power on this case.
As the stock turbo is small, that will also heavily increase backpressure and EGT when trying to get the max out of stock pump. Are you ok with a cracked cylinder head? Wink
A couple of examples, so you would get the point:
With bigger turbo and reasonable injection duration = 240hp and no smoke, no excessive heat load.
With bigger/stock turbo and very long injection duration = 239hp, LOTS of heat and LOTS of smoke. Basically this is the same even with water injection, compared to the other option.
This post was last modified: 09-19-2010, 10:41 AM by muuris.
muuris
gen3performance
89
09-19-2010, 02:45 PM #21
What is considered a dangerous egp on the 606?
gen3performance
muuris
OM605
318
09-20-2010, 02:13 PM #22
(09-19-2010, 02:45 PM)gen3performance What is considered a dangerous egp on the 606?
Depends on setup. Under 30psi is safe for sure, but can't tell a rule of thumb other than it should be at the same vicinity as boost. For example, with 20psi boost and 45psi EGP you'll be in trouble, whereas 20psi and 25-30psi is ok.
muuris
jeemu
457
09-21-2010, 02:37 PM #23
Best if boos is little higher.
jeemu
gen3performance
89
09-23-2010, 10:06 AM #24
I know this would be a band aid, but let me know what u guys think of this idea.
What if I went with the max fuel tune in the ecu and then limited the accelerator pedal with an adjustable mechanism between the pedal and floor board.
This way I will have the maximum capability of the pump and I could then adjust the amount of fuel/egt/egp on the dyno. Good idea? Bad idea? Indifferent? Possible shifting issues?
gen3performance
09-23-2010, 06:32 PM #25
(09-23-2010, 10:06 AM)gen3performance What if I went with the max fuel tune in the ecu and then limited the accelerator pedal with an adjustable mechanism between the pedal and floor board.
Such a device is already installed in every car.
[Image: h5551068.jpg]
gen3performance
89
09-23-2010, 06:44 PM #26
Not cars driven by peg legged pirates...
gen3performance
erling66
SuperDieselVan
294
09-24-2010, 06:06 PM #27
Anyone who know where to get larger elements?(except myna) or part number? I guess 7mm is the next step after the 6mm stock elements in the 606td
erling66
muuris
OM605
318
09-26-2010, 01:08 PM #28
Old Ford Transit has 7mm elements that fit in Merc M-pump.
muuris
gen3performance
89
10-02-2010, 07:06 PM #29
I went with the 215hp tune and am happy with the performance...the tune really woke this thing up!
gen3performance
300D50
Graphite Moderator, ala RBMK
10-04-2010, 06:48 PM #30
(09-26-2010, 01:08 PM)muuris Old Ford Transit has 7mm elements that fit in Merc M-pump.
Is it a drop-in, or does stuff need to be machined?
Excuse the Newb, but the m pump is the 617 type, right?
300D50
E300TSC
Turbo-Supercharged
321
10-04-2010, 07:08 PM #31
Some OM617's had the M type, others the MW. The M is found on the 60x series and the electronic version on the OM606.912 and 606.962.
E300TSC
muuris
OM605
318
10-05-2010, 10:57 AM #32
Not more than little machining required in the worst case. Haven't changed myself, but those were in my previous pump.
muuris
Olivier
10-05-2010, 12:00 PM #33
jeemu, do you mean its best if the boost is highter then the egt or highter then 20 psi?
Cheers.
Olivier
Cheers.
Olivier
10-05-2010, 12:00 PM #34
Cheers.
Olivier
Cheers.
muuris
OM605
318
10-06-2010, 12:23 PM #35
(10-05-2010, 12:00 PM)Olivier jeemu, do you mean its best if the boost is highter then the egt or highter then 20 psi?
Cheers.
Come on, use the common sense! Of course it's safe when boost is higher than egp.
The other option would mean 1psi boost and 21psi egp would be good ratio. Which is not.
muuris
Cheers.
Olivier
10-06-2010, 02:53 PM #36
Hi Muuris,
first I have no knowledge on this as its new for me, this is why I am asking questions. Second it doesn't feel like common sense to me that the boost could be highter then the EGP as the EGP come after the explosion/ heat etc... then it seems EGP should be highter at first look? Again, why I wondered.
Thank you for the knowledge tho.
Olivier
Olivier
Hi Muuris,
Olivier
muuris
OM605
318
10-07-2010, 01:18 PM #37
(10-06-2010, 02:53 PM)Olivier then it seems EGP should be highter at first look?
Then think about this: no turbo, or anything else bolted to exhaust manifold. Still got high pressure there? So it's mostly about the turbo's restriction, or ability to flow.
muuris
Olivier
10-07-2010, 04:02 PM #38
Thank you Muuris for the hint. I had to get some explaination from someone else there as I was getting confused a bit. Much better noe and its all really interesting.
All the best.
Olivier
Olivier
All the best.
Olivier
atypicalguy
12-26-2015, 04:10 AM #39
Does anyone know what the stock pump fueling level is on the om606.962? In other words, how much fuel per injector per 1000 injection events, maximum? Thanks.
atypicalguy
Petar
7.5mm M pump
459
12-26-2015, 01:56 PM #40
Don't know the exact value but it is somewhere around 60-65cc
Petar
atypicalguy
12-26-2015, 01:58 PM #41
Thank you Petar. Just trying to size up some compounds but the pump specifications do not seem seem to be widely avaipable.
atypicalguy
