STD Tuning Brakes larger brakes
larger brakes
larger brakes
oldschool5012
11-13-2010, 06:57 PM #1
are there large brakes for the w126?
oldschool5012
11-14-2010, 07:48 AM #2
For pre-1986 models yes. Post-86 brakes are larger and require 15" wheels.
Rears are identical.
For post-86 models, the only option is aftermarket.
11-17-2010, 12:35 AM #3
(11-14-2010, 07:48 AM)ForcedInduction For post-86 models, the only option is aftermarket.
Are you sure about that? I am pretty sure that the later models share the same arm with the later SL.
This post was last modified: 11-17-2010, 12:36 AM by winmutt.
11-17-2010, 01:27 AM #4
(11-17-2010, 12:35 AM)winmutt Are you sure about that? I am pretty sure that the later models share the same arm with the later SL.
If that were the case they would fit on a W123 as well.
