STD Tuning Engine Intercooler or chargecooler
HughF_UK
11-24-2010, 08:32 AM #1
I've been playing with a tape measure up front in the w201 and there isn't a whole lot of room for a big intercooler under the front...
So, got thinking about using the standard 3" chargecoolers that are floating about on ebay at the mo... I see a few people on here have used them, and a close friend has two of them on his boat and they seem to work well.
It would keep things a bit less cramped up front...
Any thoughts?
HughF_UK
Any thoughts?
muuris
OM605
318
11-24-2010, 02:41 PM #2
First thought is.. what do you mean by chargecooler vs intercooler, aren't they the very same thing? Perhaps you mean water-to-air vs air-to-air coolers?
I've seen decent intercoolers on W201s. As they are simple and cheap, I'd put one, too.
muuris
HughF_UK
11-24-2010, 03:43 PM #3
Muuris,
That's exactly what I mean, yes.
Thanks for the link.
Hugh
HughF_UK
Muuris,
Hugh
11-24-2010, 06:23 PM #4
An air-water intercooler is the best option for packaging and cools every bit as well as an air-air intercooler. It can have a much smaller working surface thanks to water's higher density and greater heat capacity. Don't skimp on the radiator though, go as large as you can fit.
If you use a tube type it needs to be at least half the area of the A/C condenser (about 300sq. inches). If you use a radiator style something at least 50sq. inches (from a motorcycle for example) will work.
A transmission cooler will not be remotely big enough, it needs to reject enough heat to get the water as near to ambient as possible at full heat input.
This post was last modified: 11-24-2010, 06:29 PM by ForcedInduction.
George3soccer
11-24-2010, 08:11 PM #5
Would the stock ac condensor unit work as the tube type.
George3soccer
11-24-2010, 08:48 PM #6
Yes, thats exactly what I use. Even after a hard run the lower 1/3 of it has always been cool to the touch.
For a pump, the circulation pump used on every MB's heater system is just about the right flow. A fluid reservoir isn't needed but you do need an expansion (air) tank.
This post was last modified: 11-24-2010, 08:51 PM by ForcedInduction.
11-29-2010, 04:06 PM #7
Check the W201 forums, there is a number of people who have AA ic however AWIC is still the best option.
George3soccer
11-29-2010, 04:57 PM #8
you mean 190rev.net
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
you mean 190rev.net
Mb 2004 w203 C230k
11-29-2010, 05:20 PM #9
That is one. Even benzworld would be a good one. PP and bw are good for different reasons, I like the segmentation by chassis in bw.
