STD Other FS / WTB / Buying guides Electrical/mechanical prototyping, short run manufacturing services.
300D50
Graphite Moderator, ala RBMK
02-10-2011, 05:20 PM #1
I offer short run and one-off machining services, CAD services, electronics prototyping, design, and fabrication services, as well as general consulting in the electrical and mechanical fields.
Some examples of past jobs are
  • machined adapter plates
    conversion fittings (jic to british metric, AN flare to A/C flange, fuel rail adapters, etc. If I can get an example of the ends it can likely be made)
    EGR block off plates
    custom controllers
    circuit board rework and repair(depends on parts availability and complexity)
    DC motor interfaces and controls
    self contained solar lighting
    shift knobs
    embedded electronics for remote sensing
    other odds and ends
I now have the ability to do custom digital gauge sets for things like boost and EGT, oil temp, water temp, fuel pressure, and the like.
The display can either be a re-purpose of an existing gauge, a character LCD display, a 7 segment display, or even a simple bar graph.
As for senders, I can adapt around most any OEM unit, or devise a custom solution to fit the need at hand, including adapter fittings/interconnect work if needed.
My rates are on a per-job quoted basis, and turnaround time is job dependent.
It is best to contact me via email or PM, email preferred.
Walt
Zarnochwf1@ABCPrototyping.com
300D50
    custom controllers
    shift knobs
    other odds and ends
Walt
02-14-2011, 01:37 PM #2
I need a SMC ship mounted on a shield board for the arduino, is this something you can do?
300D50
02-14-2011, 02:58 PM #3
Get me a datasheet, and I'll see what I can do. I can reflow most leaded packages, but I'm just getting the hang of BGA.
Is it a pre-made shield with a footprint, or would I have to get one made?
To the oil filter plate guys.
I've got the basic design finished, still have to get a stock quote.
winmutt, think we can split all the oil filter relocation posts into another thread for clarity?
This post was last modified: 02-14-2011, 03:07 PM by 300D50.
300D50
02-15-2011, 09:51 AM #4
(02-14-2011, 02:58 PM)300D50 Get me a datasheet, and I'll see what I can do. I can reflow most leaded packages, but I'm just getting the hang of BGA.
This is the daughter board I made. I have to get my hands on that SMC to get model number and data sheet.
stan
02-15-2011, 12:45 PM #5
(02-14-2011, 01:37 PM)winmutt I need a SMC ship mounted on a shield board for the arduino, is this something you can do?
if 300D50 can't do it, shoot me a PM. i'll show you some <.5mm pitch tssops i just did the other day Big Grin
stan
300D50
02-15-2011, 01:06 PM #6
I've got a reflow oven, I'm just not that good at BGA yet. I can also hand solder tssop, chiped a few PS2's with Kynar wire as well. :p
300D50
02-16-2011, 12:38 AM #7
I reflowed my sisters laptop in the oven the other day! Tongue
300 Can you finish a design of a VU meter using 2 LM3916's for each channel. There are two cascaded for each channel. I had an electrical engineer start the project and has dropped the ball on me...
http://www.national.com/mpf/LM/LM3916.html#Overview
This post was last modified: 02-17-2011, 02:01 AM by Captain America.
300D50
02-16-2011, 09:48 PM #8
Hehe, oven reflow.... what temp ya have it at? :p
Shoot me a PM with more info, looks to be very easily done.
300D50
02-17-2011, 02:01 AM #9
8 min @ 385 Degrees IIRC
02-23-2011, 01:26 PM #10
EGR block off plates?
300D50
02-23-2011, 02:29 PM #11
Easily doable, just need to find my EGR valve.
300D50
02-23-2011, 05:46 PM #12
Probably worth doing a run of 10 if its cheaper. I am sure others here an on the other boards would be interested. I dont think Brian Carlton is selling his anymore.
300D50
02-23-2011, 06:14 PM #13
I could likely do a batch, 1/4 or 3/16 plate is all that's needed for the intake side, the exhaust side is the tricky part, but I can get it to behave. Wink
300D50
02-25-2011, 11:11 AM #14
I have no need for the exhaust side. What has been done in the past is to take a simple piece of sheet metal and drive it over the pipe with a slightly larger id pipe and then use the stock clamp.
300D50
02-25-2011, 11:21 AM #15
That makes my job that much easier!
I'll start in on that once this plate run is finished.
300D50
