STD Tuning Engine 240d center motor mount?
05-30-2011, 12:58 PM #1
So when I was pulling the engine yesterday I removed the shock and the motor mount bolts only to find that the engine still would not come out
I crawled back under to find another engine mount in the center of the oil pan to the cross member dose any one know where to get a new one?
I plan on replacing all of the motor mounts while in here!
MB TECH
05-30-2011, 01:35 PM #2
I replaced mine about 6 months ago, didnt have any luck finding one aftermarket. I just got it from the dealership.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
05-31-2011, 04:21 PM #3
Are you talking about this... AutohausAZ? Same t-mount smoke linked up.
05-31-2011, 04:25 PM #4
Mine looks different than that it bolted to the oil pan with 2 bolts but fit over a 1" flat tang on the front of the cross member?
05-31-2011, 04:36 PM #5
(05-31-2011, 04:25 PM)willbhere4u Mine looks different than that it bolted to the oil pan with 2 bolts but fit over a 1" flat tang on the front of the cross member?
Then it could be a dealer item as MB Tech noted.
Hercules
06-01-2011, 02:50 AM #6
These mounts never worked very well ,if at all,many times more vibrations were caused by the mounts. Mbz issued a bulletin on how to adj. trying to rid engine of vibrations caused by mount.
Hercules
