STD Tuning Engine om617 firing at 4cyl cold. 4,5 warm and 5cyl when at full throttle and boost
BRABUS
07-26-2011, 12:57 PM #1
hi.
Was doing some test runs today, and suddently i heard a high freq knocking noise. then it was "misfiring" on one cyl when i drive with only follow throttle, but when i floor it and get boost it shoots away like it did before. Injector problem maybe? Any ideas?
This post was last modified: 07-27-2011, 01:15 PM by BRABUS.
BRABUS
hi.
BRABUS
07-26-2011, 03:56 PM #2
anyone?
tried to hold on the injector lines near the injectors when the engine is running. And i can feel the pulse at all injector except injector number 3. It was only a pulse there sometimes. not sure if this is something usefull, maybe it just was my head that told my it didnt pulse as much as the other injector lines.
This post was last modified: 07-26-2011, 04:06 PM by BRABUS.
BRABUS
anyone?
tomnik
07-26-2011, 11:36 PM #3
any leaks in the injector lines?
One nozzle clamps (needle blocks)? This is normally related to a certain rpm range only.
Tom
tomnik
Tom
BRABUS
07-27-2011, 01:07 AM #4
(07-26-2011, 11:36 PM)tomnik any leaks in the injector lines?
Tom
no there is not any leaks at the injector lines.
i started think about the valves, i recently did the valve adjustment could it be one of the adjusment nuts that has loosend and causing bad compression when not getting boost? I think its wierd because it pulls like hell when i first floor it and get boost, but before boost there is a rattling/knocking noise and you feel its not firing right at one cyl.
BRABUS
Tom
Hercules
07-27-2011, 03:44 AM #5
Possible sticking inj. Try holding a lg.screwdriver on inj. line, handle end to ear, if diff. sound than others pull inj.
Poor fuel quality can cause inj. to start hanging . Many times is water in fuel,suggest to carry fuel add.First sign of missing,poor running,nailing, install add. Other problems ,fuel is just to dry,inj.overheat,again install add.
Hercules
BRABUS
07-27-2011, 01:11 PM #6
hi. Tried to losen the injector line to cyl 2 nothing changes. Then i swapped cyl 2 and 3 injectors, and still no change. so the engine is getting diesel.. But when it is cold it just run on 4cyl, but when its warm it runs at 4cyl but you can feel the 5th cyl wants to ignite. Any thougts? the noise is when the 5th cylinder start to ignite....
BRABUS
07-27-2011, 02:34 PM #7
Very strange. Wish I could help
BRABUS
07-27-2011, 03:24 PM #8
i also wish you could help me Smile if its not some easy fix. i have to park until next year. have to begin engine build and swap on my 98 E230 turbo soon
BRABUS
Oil Burner
Turbo Everyting!!!
83
07-27-2011, 03:55 PM #9
Try to loosen 2 injector lines at a time, you should feel, hear, and see a major difference in the way the engine idles. if you find 2 that do not make a drastic difference, tighten one and open a different one if you find a drastic difference its the one you tighten if it’s not a drastic difference tighten the other one of the first 2 and loosen the other one again to verify. This is a very easy way to identify a injector not performing at its best but yet still working a little.
Hope this helps
Oil Burner
Hope this helps
BRABUS
07-27-2011, 04:02 PM #10
Oil burner.
I most likely found out that nothing wrong with injector ...
When its warm it idle at 4,5cyl. but when i open the injector line on injector number 2 it goes from 4,5cyl to 4cyl and its squirting diesel from the nut on the injector line... so im started to think the problem is valves or lower compression rings ?!?!? . because the the cylinder 2 wonth fire until the engine gets warm, and then it only fires at 50%. But when it get full throttle and boost it works like hell Smile
BRABUS
Oil burner.
Hercules
07-27-2011, 06:15 PM #11
Recheck valve clearance, also ck prechamber ball,can burn and fall off, blocking exit hole part time,and will be noisy(rattle,knocking).Worn valve guide can also cause low speed miss, Low compression>
Hercules
BRABUS
07-28-2011, 08:52 AM #12
gonna check the valves now... if it was bad comp, wouldnt i have pressure in the crankcase/blowby? its not much pressure in the crankcase, even when im driving at 2.5bar for boost. The ball in the precamber can fall off? where in the prechamger is it mounted?
BRABUS
randomdude
07-28-2011, 09:21 AM #13
if you dont say what year/make/model/engine you have, then you should put it in your sig, so we know what we're working with.
cars? what cars? WHERE???
randomdude
07-28-2011, 09:25 AM #14
wut? it says om617 in the title.
07-28-2011, 09:53 AM #15
(07-28-2011, 08:52 AM)BRABUS gonna check the valves now... if it was bad comp, wouldnt i have pressure in the crankcase/blowby? its not much pressure in the crankcase, even when im driving at 2.5bar for boost. The ball in the precamber can fall off? where in the prechamger is it mounted?
Its directly under the injector if you have the injector out you can look down there with a flash light and see it there
glow plug prechamber and the little ball are in there
The ball glows red hod after the engine is running it ignites the fuel before it come out of the prechamber its like the glow plug but it stays hot with every ignition of fuel
The prechamber screws into the head and the injector in to it the ball is inside of the prechamber along with the glow plug!
Here is a pic of a bad one for comparison taken off some where else on this sight! not mine
This post was last modified: 07-28-2011, 10:02 AM by willbhere4u.
BRABUS
07-28-2011, 10:34 AM #16
if nothing changes after i adjust the valve i wil try to remove the injector again and take a look down into the prechamber,.,
BRABUS
07-29-2011, 10:25 AM #17
Did you turn the element holders? This sounds like an injection pump problem to me.
BRABUS
07-29-2011, 02:05 PM #18
i havent touched the ip after i got it back from pp diesel in finland. and when i loosen the injector line at the injector at the cyl it is misfiring at, its squirts diesel. wee wil se when i innstall the pump on my new engine. Removed engine today, new engine new in a week or so Smile
BRABUS
07-29-2011, 03:01 PM #19
Sounds to me like a delivery timing issue in the IP. This is an M or MW pump?
BRABUS
07-29-2011, 03:46 PM #20
this is a m pump. if its the ip its strange that it just suddently happend, the car has worked great for almost 2months with this ip.
BRABUS
07-29-2011, 04:05 PM #21
Delivery valve seals maybe?
BRABUS
07-29-2011, 04:42 PM #22
will see how the new engine runs with this pump. If still misfiring at cyl2 i will look at the ip.
BRABUS
07-29-2011, 05:34 PM #23
I would verify cold and hot compression on all the cylinders. If they check out as being even, then it's an IP issue. Perhaps as simple as a DV seal as 'mutt has suggested. [/align]
BRABUS
07-30-2011, 01:02 PM #24
the engine is out so i dont worry anymore whats wrong with it. but im pretty sure its bad compression because of all the grey smoke caused by the one cyl misfiring. but thanks for your ideas
BRABUS
Drivmerc
Schwitzer S200
10
07-31-2011, 05:29 PM #25
Hi
On my 240D it happened exactly same thing
i did some runs and then when I stopped and let it cool down a little bit
at first it run on all 4 suddenly when i rev it it missfired and then it missfired at idle to so drove in the garage check the valve adjustment injectors took a comp test and had 14bar on 2 cyl took of the cylinder head and saw that my headgasket has blow by beetween 2 & 3 cyl and then test the valve leakage and all valves was leaking by a little bit
It may not be the same problem but it sounds like it should be the sameBig Grin
Drivmerc
Hi
BRABUS
08-09-2011, 05:56 PM #26
new engine mounted, nothing wrong with the IP...
BRABUS
dieselboy
Rotatin 5500 times a minute
680
08-09-2011, 08:15 PM #27
You going to pull the head and see what's wrong with the old one? You think it dropped a precup?
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
BRABUS
08-10-2011, 07:34 AM #28
Will look at the broken engine next week. will post a update here when i find out what happend to it
BRABUS
