STD Maintenance General IP vacuum ports
IP vacuum ports
IP vacuum ports
Gasoline Fumes
Diesel Fumes?
54
03-20-2009, 08:05 AM #1
Could someone tell me what the different vacuum ports on my '85 IP do? I pulled all the vacuum stuff out and want to start from scratch and keep it simple. I understand the ALDA, but why the two connections on it? I can eliminate one, right? Which is the shutoff? I have a diagram, but it doesn't show everything and it certainly doesn't tell me what I can remove.
Gasoline Fumes
03-20-2009, 12:59 PM #2
A is boost to ARV
B is boost from manifold
E is shutoff valve i think (not sure where it goes.
C is vac vent from cabin
D is either from the main vac line or to the trans cant remember.
A is boost to ARV
03-20-2009, 03:14 PM #3
That is right. A and B can be combined into 1 port.
Gasoline Fumes
Diesel Fumes?
54
03-21-2009, 02:45 AM #4
Thanks! Smile
Gasoline Fumes
Thanks! Smile
03-21-2009, 11:44 PM #5
A makes a handy place to pull boost signal for gauges IF you have no leaks. Otherwise it is a REALLY bad place to leak...
Gasoline Fumes
Diesel Fumes?
54
03-28-2009, 12:24 AM #6
Why is a leak there really bad?
Gasoline Fumes
03-28-2009, 09:33 AM #7
If you leak to the ALDA you will lose fuel.
Gasoline Fumes
Diesel Fumes?
54
03-29-2009, 03:02 AM #8
That's what I thought, but "REALLY bad" made me think something worse would happen. Like mechanic damage or something.
Gasoline Fumes
