STD Tuning Engine 300CD IP Tuning... Lack of Fuel?
bmwpowere36m3
10-17-2011, 04:22 PM #1
I filmed my 300CD after doing some IP tweaks. I still can't get much smoke if any... I'm wondering if I'm getting enough fuel?
  • Stock 617.952 motor (~200k+ miles)
  • 14psi MAX w/ wastegate fully tightened (w/ wastegate hose disconnected, 19-20psi MAX)
  • ~1100F MAX temps on a LONG pull
  • ALDA Removed
  • Rack Limiter Removed
  • Horizontal Throttle Stop turned in 1/2 turn
  • EGR System Removed
  • 4spd MT
  • 2.47 Diff
Engine has been serviced: adjusted valves, corrected camshaft timing (was ~8 deg off), adjusted IP timing (24 deg), replaced both filters, cleaned tank screen and replaced air filter. I run on a mix of diesel and 5% B100.
Click Here For 300CD Vid
This post was last modified: 10-17-2011, 04:24 PM by bmwpowere36m3.
'80 MB 300CD, "Beauty"
'98 BMW M3, The BEAST
bmwpowere36m3
  • ALDA Removed
  • 4spd MT
  • 2.47 Diff
10-17-2011, 05:03 PM #2
Did you try stretching the spring in the lift pump? to make sure your getting full pressure to the injection pump?
There are some treads on this subject
ronnie
10-17-2011, 05:33 PM #3
he has stretched the spring but not checked to see what the pressure actually is yet. If the fuel pressure does turn out to be ok then it could well be the torque capsile needs to be turned up a bit.
Just noticed 2.47 diff? must be a slug off the line, great for cruising though.
ronnie
10-17-2011, 09:03 PM #4
I never noticed any smoke until i turned in the horizontal throttle stop a couple turns and adjusted my rack limiter, even then it was only a haze when i floored it in nuetral. The most noticable chang is the torque capsule for sure. It really let the coal roll Big Grin
bmwpowere36m3
11-22-2011, 06:38 PM #5
(10-17-2011, 05:33 PM)ronnie he has stretched the spring but not checked to see what the pressure actually is yet. If the fuel pressure does turn out to be ok then it could well be the torque capsile needs to be turned up a bit.
Well, finally got a chance to check my fuel supply pressure (after main filter, before IP):
Unclamped Return
Idle: ~13-16psi (unsteady reading)
3k RPM: ~20psi (steady reading)
Clamped Return
Idle: ~20psi (steady reading)
So it appears reasonable...
This post was last modified: 11-22-2011, 11:25 PM by bmwpowere36m3.
bmwpowere36m3
Unclamped Return
Clamped Return
ronnie
11-23-2011, 06:49 PM #6
It is reasonable. I am surprised you do not get more with it clamped off though. Should max out about 30 psi. You should have enough to do some ip adjustments. if you really get into it you may want more fuel pressure.I am running 28 psi at cruising speed, about 20 at idle. Don't forget to get an egt gauge before doing ip work. The rack limiter can be adjusted some as a first step. the rest you should read up on really good before jumping in. There is a good post in this forum "thoery of m/mw pumps" that gives a real good primer on ip adjustments.
Guess it has been a while, should have read your first post again. Your next step is going to be torque control. Be real careful and follow the guide on this one. This will give lots of smoke if to heavy handed. Would suggest 1/2 turn increments to start with. I have mine at 2 turns in, and this is a bit aggressive. I have to watch my egts, and look in the mirror to see if I am smoking someone out.
This post was last modified: 11-23-2011, 06:53 PM by ronnie.
ronnie
