124 rear subframe upgrade
swapped in the entire rear subframe from a 1994 E420
this includes the larger 210mm diff housing
and the much beefier steel frame/mount
not to mention the brake upgrade
so the subframe basically just bolts in, but this is the strange part..
the center support bearing in the M119 V8 cars is not located in the same position in the tunnel as the non V8 cars.. not sure why they did this but
I had to have a custom driveshaft rear section made longer the the E420 unit
so the stock 185mm diff had a 2.65 final drive ratio
the new E420 unit has a 2.24 gearset, and running the 18 inch wheels
my effective final drive ratio is an amazingly tall 2.17
now that the swap is complete, stop and go city driving is a bit sluggish, but as I drive this car mostly on the highway, its a great tradeoff.. highway RPMs are way down and I am pretty sure I will pick up some better fuel economy.
I think this will be even better with the planned 5-speed swap
as my tachometer is currently not working and the speedo is horrifyingly inaccurate , I cannot report RPM to speed numbers right now... stay tuned.
nope...
Hey, can you take me for a ride in your fail boat?
J/K 2.17's have to be nice on the freeway. Did you manage to get the speedo drive from the car you got this from?
(04-21-2009, 12:37 AM)kamel Hey, can you take me for a ride in your fail boat?
Damn, you had me going for a minute...I thought this was swapping the 124 rear into the 123. That would be sweet...
