My OM617 Build
My OM617 Build
I've got the engine out of my '82 300D, eventually it will be mated to my '89 Ranger's drivetrain.
Here are the plans:
Ditch the GT2056V
Long tube exhaust
Holset HE351V
W115 Intake
A/A Intercooler
Progress:
Vac pump half removed, rack limiter removed, engine on a stand in the garage...
Pics to come...
Read the IP doc, before you remove the rack limiter.
Unfortunately it was sent to me literally 15 minutes after I pulled the limiter. I don't think it's going to go back in easily.
Wow was that thing in the ocean?
And some W/M injection? Sweet!
Trimmed the vac pump housing today, now I've got to weld a plate onto it to make up a blockoff cap:
Brazed the vacuum bllockoff cap together today, now I've just got to clean it up with the grinder:
http://www.weldingtipsandtricks.com/alum...-rods.html
Where should I mount my turbo and what manifolds should I use?
I'm torn between piping the '78 N/A manifold with it's long runners to up near the alternator:
or...use the crappy stock exhaust manifold and get a W115 intake one day:
What do you guys think?
Also, I blocked off the heater return line to help with clearance issues :p
Mounting, supporting the weight, routing boost tubes, routing your exhaust, and making your oil drain will be much easier with it in the stock location.
Lightly port matched the head tonight!
I decided to pull the whole head so I could check the bores/ pistons/ prechambers and port the head. The bores are within ~0.0015" and everything looks great. Lightly ported the head, it's in the parts washer right now.
Stock Valve Area:
Modified Valve Area:
I have a spare w123 and a spare '84 ranger in my backyard, now you have me considering a project like this! Im just not sure what the smog requirements/laws are in california about this sort of thing
Once I have everything put together I will be posting prints for the adapter plate and bearing alignment plug. Just be sure to put a 1984 or 1985 om617a into the 84 ranger and you're fine.
We will see how the HE351V spools I have heard of people using it on 2.3L gas motors, so I should be able to use it with the 3.0L. I will be monitoring exhaust pressure as well as temperature.
Does anyone know what exhaust pressure the valves start to float?
(01-31-2012, 09:10 AM)Simpler=Better We will see how the HE351V spoolsI have heard of people using it on 2.3L gas motors, so I should be able to use it with the 3.0L. I will be monitoring exhaust pressure as well as temperature.
Anyone need parts from a Ford 1989 2.9L V6?
How thick of a plate and what material would y'all recommend I make my adapter from?
(02-03-2012, 08:52 AM)Simpler=Better How thick of a plate and what material would y'all recommend I make my adapter from?
Not much porgress lately, just cleaning stuff:
Installed the OEM block heater today, along with a new main seal!
I am guessing you are planing on using the Ranger flywheel, I was doing the same swap but in 2wd using a 240 flywheel, but it is too large to fit in the bell. I'm not sure you will be able to use the ranger flywheel due to the small diameter because the starter has to fit close to the block and if memeroy serves me correct there is not enough room. So the other option is a trans from the F150 and 300 6cly flywheel or 240 flywheel.
Yeah I'm going to "have fun" adapting the flywheel. I think I will be making a frankenflywheel, the Ranger flywheel is definitely too small to just drill new holes.
HOLY SHIT!
Lol!
Yeah my buddy had never been around a diesel with no pipes, much less a 617. Before we started the engine I warned him about the potential for a runaway diesel (since I had played with the pump while it was out). When it flared to life at "half throttle" he ran out thinking it was gonna blow
I can't decide on what I want to do for my turbo. I have the 2056V setup and ready to go, but that would limit me to ~18psi (which I'm confident I can supplement with methanol).
The HE351V will give me 25psi no problem, but I doubt I can dump enough methanol to burn the extra 10psi of air.
Thoughts?
**EDIT**
I'm going to run the 2056V and stock manifold for a while. Once I figure out my fueling situation I'll worry about more air.
Good idea. Check out how it runs with 18 psi first
I got my head out of the clouds, I'll get it running, in the truck, and THEN worry about more air.
Is that a Toyo Kogyo 5-speed? Might know a customer...
Where are you seeing a transmission? The trans I'm hoping to use in my conversion is a FM146 from an '89 Ranger
Ah. My bad.
I decided to go back to the 2056V. I'm looking to push "14psi" of fuel with the stock pump and then add enough methanol to burn up an additional 4-5 psi of boost. If I get my hands on a super pump one day I'll upgrade to the Holset 351V. I'm hoping to finish porting the manifolds and rigging up the turbo lines by this weekend. The stock log exhaust manifold had some major imperfections-port #1 had a grape-sized obstruction.
Playing with the GT2056V:
Sounding good!
I like the white. Nice contrast to diry old and rusty.
Pardon my ignorance, but, what's the purpose of all that tubing on the intake manifold?
It's a port-injection methanol setup. Each runner has a bung welded on and a 1GPH sprayer nozzle attached internally.
Ah, of course. Thanks! Hadn't had my morning coffee yet. How is the flow rate control accomplished, if I may be so bold?
The nozzles are rated at 1GPH @ 100psi (I got them from McMaster-Carr for ~$7 each). My pump supposedly runs at a "constant" 120psi, so I'm leaving it to fluid mechanics to properly regulate.
As I have no w/m injection experience at all, but do have a CoolingMist Cool250, bought from Craigslist, adjustable from 100 to 250 PSI depending on nozzle size, but set at 200 PSI from the factory...I am naturally hoping to learn from your experience!
Hi
Nice project. Did the methanol/water injection work fine? did you feel any increase in power with it? Mow much water vs methanol?
Are there anyone that runs a 617 with a HE351V? According to Forcedinduction it will be way to big and end up on the wrong side of the surge line? The 617 isn't exactly what you would call a race engine The VE is probably in the seventies?
The HE351V has been run on Ford 2.3L motors (redline around 5,500) so I would assume that you could run it on a 617, you would just want to monitor your EMP and turbo RPM.
I would be willing to bet that with the proper fueling & setup, the HE351v would do just fine. FI was using a "FI tweaked" pump that may not have been optimal. With what we know now about pumps, I bet OM616 could make it work....
Ed
I'm sreiously considering putting this into a Wrangler instead, IF I can find a cheap Wrangler. There's a CJ5 up here for $1k, no top.
